OT Copying VCR to DVD
Stuart Johnson
I have several woodworking VCR tapes I would like to copy to DVDs. How is this done? I have a vcr and a DVD player/recorder we now use for recording tv shows.
These are all purchased tapes so I'm not ripping anyone off.
Re: OT Copying VCR to DVD
Bill Howatt
Get a set of cables with the RCA plugs on them that fit your input and output connectors on the VCR and DVD recorder. Connect the outputs of VCR to the inputs of the DVD recorder. You may have to go to the DVD menu and select the inputs instead of say Channel 3 or whatever other inputs it has available. The female jacks on the device are usually colored red, white and yellow for audio right channel, audio left channel and video respectively.
You may find that it doesn't work very well since the tape may have some form of copy-guard on it which will cause color shifts and unstable picture on the copy. You just have to try it to find out.
Look in your DVD recorder book for recommendations on the type of DVD it will record on such as -R or +R. If it will record on re-writeable (RW) DVDs consider using one of them while you are experimenting. Once the others are used once they cannot be erased.
Bill
