Re: Grant in Iowa - paging Grant
Grant in Iowa
Hi Carol,
While the John Deere 116 is classified as a lawn tractor, it would likely work fine for your light duty needs. I'd equate it to an entry level garden tractor available today. I wouldn't pay $300 for it, however. Maybe $150 if it is all there and you have a line on a mower deck. The limit of its towing capacity will be traction, which can be improved with different tires or just some weight on the rear axle (not a reference to the drivers girth!). Also keep in mind that the same limits apply to braking in a down hill loaded trailer situation.
I'll assume John Deere is popular in your area. It should be a fairly simple matter to locate a used mower deck and snow blade/ snowblower for that machine. Part of why the major brands are better bets for a used buyer.
So long as the snow you get is fluffy and not wet and heavy, the snowblower is the way to go, as it puts less stress on the drivetrain. I'll confess I am not sure how often or how much you get snow in your area. If the snow is often wet and heavy, then a blade may be a better option as snowthrowers often clog with wet heavy snow. A blower would be best for fluffy or heavy snowfalls.
The ad talks about the tractor not running. Be cautious and make sure the engine at least turns over before laying any money down. Reason is that if you can't determine that the engine and transaxle are in working order, it may cost more than the tractor is worth to fix it. Yes, John Deeres hold their value, but that may be too much for a tractor that may have unkown problems. The good news is that parts area readily available for it from a JD dealer, if a bit expensive. Also note that John Deere doesn't have a monopoly on engine parts, so you can note the model # of the engine and find them online from various sources at a discount.
At least here in Iowa, that tractor in that condition would be $100 max, but you can judge what it is worth in your area based on the other ads you've seen.
Anyway, sorry for the slow response, I was travelling.
FWIW,
Grant in Iowa
