OT Large screen TV for computer monitor?
Carol Reed
Anybody doing this?
I am told that a HDTV with a PC port can be used this way.
Comments, caveats, crazy or not?
Have to give up my 4 monitor set up, so would like one very large monitor to have multiple windows open simultaneously. The large screen would be on the wall about 7-8 feet away. Or whatever it needs to be....
I am going blind using my notebook everyday.
Re: OT Large screen TV for computer monitor?
Hamish
Good morning Carol,
I sometimes connect my laptop to our 32" HDTV to share photos with all the family, which works great. What you see on the TV screen is the same as you see on the laptop but enlarged and to the same proportions. It does not give you any more space to open and see multiple windows.
I am a Mac user and have found that their new 27" panoramic screen iMacs really give you a lot more space to see various windows open at once than my laptop does. There is enough space to put two A4 document pages at 100% side by side with some extra to spare. Of course, these documents can be enlarged considerable to help those with poor eyesight. Another thing to consider, is that any desk top screen can be better placed for comfortable viewing while typing than when using a laptop.
Hope this helps.
Hamish.
Bill Blasic
Bill Blasic
Carol,
I just got a new computer and the video card has a HDMI out so I picked up a HDTV/Monitor (24 1/2") and used that to do the computer on. It also has the VGA connection so I might try hooking up one of the other computers to it also. I must say that the picture is great and the computer has enough power to watch a movie and have many more windows open and working. It is a Samsung HDTV/Monitor from SAM's Club.
Bill
Carol Reed
So this is HDMI out of the computer's video card and PC input on the large screen? Or is there an HDMI input on the large screen?
I am trying to figure out how to equip the new computer and what to look for in the new large screen.
A bonus for me would be to watch a movie of TV program from the Internet, but it only a bonus, not my primary reason for attempting this.
Thanks, I did not know there was such a thing as a HDMI output on video cards. That helps.
Bill Howatt
Just to add a bit more info that might help you or someone else. Yes, there are video cards with HDMI outputs and if there isn't one, you can buy a DVI - HDMI adapter for around $10. A DVI connector is the rectangular, white digital connector that is now common for connecting digital monitors (usually LCD) instead of the "old" analog VGA connector.
The only difference when using a DVI input or output is the absence of audio. HDMI is both video and audio whereas DVI is video only.
I had the opposite problem, my LCD TV croaked and I used my 24" wide monitor as a TV set. My satellite receiver has HDMI out and I converted it to DVI for my monitor. Used the analog audio output from the receiver into my amplifier for the audio.
This stuff is changing so fast it is hard to keep up with it.
A bit more obscure info. HDMI connections also have digital rights management which in simple terms means it can check for illegal use of the content by the hardware in a HDMI connected device. You are unlikely to encounter this as a problem in a TV setup.
Bill
John McGaw
Sure, it can be used that way. Whether it is satisfactory is up for discussion. I built an HTPC (Home Theater PC) and it is connected to my 42" Sharp HD flatscreen. I would never consider that a satisfactory situation. The default resolution of 1920 X 1080 mixed with the sheer area is the main problem meant I've had to reduce the resolution to the lower 720P HDTV standard to make it usable at all.
Right now I'm typing on my newest build -- an Intel i7 machine running Windows 7. If this OS was running on the HTPC it might be a bit more satisfactory since it gives more options for adjusting the display characteristics (the HTPC is running XP Media Center now) but it probably would still not be satisfactory. This Windows 7 machine uses a 23" flat panel monitor with identical 1920X1080 resolution and this works out well since the screen is all of 18" from the tip of my nose and it also allows multiple application side-by-side.
I have a second 20" flat panel hooked up too and will be using that mounted above the main monitor as soon as a suitable stand can be made but I suspect that after all these years I will never get used to more than a single display.
David Yoho
Carol, when I wanted to connect my wife's laptop to our Sony Bravia Flat Screen, I did a little digging around to see what my options were. This is what I got from that digging -
There are three options available, with not all being available necessarily at once. First, and generally reported to be the least liked, is S-Video that requires the proper cable to make the connection from the computer to the TV.
Second is VGA, which again requires a VGA cable for connection. This is the one I went with but I got one that included the small audio cable attached too. Since the laptop did not have a DVI or HDMI connection, VGA was the best choice for me.
Third is the HDMI connection that requires a HDMI cable. This is the best quality from what I could figure.
I also read several cautions about not trying to use a screen resolution greater than the TV could handle or damage might occur.
I have to say that I'm not impressed with the picture on the TV. I think it's the wide screen that is throwing things off but must admit to not changing the screen mode on the TV to see if that made things better. We only plan to use it now and then to show pictures loaded on the computer to friends or family. While it works alright, I'd have a hard time using it for extended periods as a computer monitor.
What is impressive, is my younger son's new Intel I7-based I-Mac with the 27-inch HD screen. As another responder reported, it's crystal clear and has plenty of real estate for multiple applications or documents at once. Sure wish the TV setup for the laptop was half that good!!
David
It depends
Much depends on your video card and resolution and capabilities. Some TV/computer combinations look horrible (fuzzy, etc) so if possible try before you commit. The type of connection you make can make a big difference. I've carried a laptop into a store before and they let me hook up to display models on the floor.
As for more screen space - look at the options available with your display card (laptop?). Right click on the desktop background (Windows machine) and choose Properties/Settings and check the possible screen resolutions. Some drivers have more settings under the Advanced button. Most laptops are fairly inflexible in the options, typically set for optimum use with the built-in screen. Unless you have some higher-resolution modes available you will not see any more than what you see now, it will just be bigger and likely not as sharp. You have to deal with having the wire stretched across the room as well, plus a long hdmi cable is not cheap.
I've been trying to get used to a single-monitor on this laptop ever since I quit using my graphics workstation. I worked with large dual monitors for at least 20 years, sometimes several sets at once. The way to go for photo editing, 3D graphics, animation, video and audio production, etc. This was one side of my basement studio:
John McGaw
Many, if not most, video cards (and new laptops for that matter) have a standard HDMI output. Many large-screen TVs have a 15-pin VGA input, some have a DVI input, but every large screen HD set should have at least a couple of HDMI inputs. HDMI is probably the easiest connection between computer and HDTV since it transmits the highest quality video and the audio at the same time. I would not even consider S-Video for a computer to TV connection -- the resolution is not good enough and the video generally "smears" for lack of a better term.
Personally, I much prefer a 23" or larger flat-screen monitor for a computer since I find that a large screen TV requires you to sit too far back to take the whole thing in comfortably. Additionally, many older computer operating systems seem to lack any provision for display settings which make such huge displays comfortable.
If you actually wanted to watch TV on the computer it is common to have a receiver card in a modern computer, either standard or as an inexpensive option, and modern PC operating systems (Windows 7, and Vista for sure) will turn the computer monitor into a fine TV display and the computer into a digital video recorder capable of automatically recording programs. A modern computer will also come with a DVD drive for playback and recording which can play back through the computer monitor.
The options seem endless and probably endlessly confusing also...
Scott Greaves in Blackfoot ID
Not a real suggestion, but I'll tell you what I did recently.
My Dad lives at the Veterans Home, and he wanted to buy them a better way to do bingo. He couldn't hear them call out the numbers. I did a little research, and figured the best way was to get a laptop and load some bingo software on it. This worked great, but wasn't large enough for everybody to see, so we got them a 58" plasma TV to mount on the wall. This TV came with all kinds of connections we could have used, but what we did, so they wouldn't have lots of wires running across the floor for people to trip over, is we bought a wireless device. It's called a PCtoTV by Addlogix, and it uses the wireless card in the laptop to send video and audio to a receiver that then hooks to the TV by way of componant cables and an audio cable. This is not going to deliver the sharpest picture, but it does much better than I thought it would. Computer, TV, PCtoTV and all mounting hardware only came to about $2200 after Best Buy gave us everything at their cost (since it was for the Veterans!), but still that's not bad for such a huge display.
Scott.
Dave Paine
This can be done, but whether it will replace your 4 monitors, only you can decide.
I have a Sony Bravia 52inch LCD TV. It has a PC input option. I connect my wife's laptop so that we can stream internet radio. The tuner for her favourite station gets too much interference.
The TV's have a maximum (at present) resolution of 1920 x 1080.
The laptop display looks very good on my Bravia, but the number of horizontal pixels is really less than 2 x a normal monitor of 1280 x 1024.
This feels like it may replace two of your monitors, but not 4.
I have just purchased a 24 in PC LCD which has 1980 x 1080 resolution as a second monitor and I love this, but I am replacing a previous second PC LCD whose power supplied died.
Re: Redo -OT Large screen TV for computer monitor?
Carol Reed
I guess I'd better back up and explain.
I need a new desk top. Don't mention Apple. It ain't in the budget. My old desktop supported 4 analog flat screens. It is 6 years old. The power supply is marginal and now the primary video card has memory errors. It doesn't make fiscal sense to me to just try to replace the video card, even if I could still find one that fit the mother board.
New video cards have digital outputs and yes, I know I can get digital to analog video adapters.
But I considered trying to recover some desk real estate, thus the large screen TV idea. I would use the larger screen to have several windows open simultaneously and sized by dragging corner to best utilize the space available.
That brings up how large is a large screen? Don't really know. Resolution would be a big thing. I am hearing in your commentary that it could also be a PITA!
A new computer with one video card will support two monitors. A second card could support the other two. That is one option. I was trying to simplify things, but may be this isn't such a good idea.
Second option is to learn to live with two monitors. It wold be a major improvement over the tiny screen on the notebook which is driving me nuts at the moment.
Major computer usage is text in some form or another. Some photos and occasionally watching an episode of NCIS on-line. Video is currently limited to a little YouTube. Maybe someday I will learn how to generate an edited video and post one on YouTube. That would be a first.
Appreciate your comments. Sounds like I still have to decide something.
Dave Paine
With your clarification of the setup, I think two monitors which support 1920 x 1080 would be a replacement for the present monitors.
I do not think monitors are presently going beyond 1920 x 1080 which is the "Full HD" resolution. I expect this will be exceeded at some point.
I am using 24in 1920x1080 and 22 in 1600 x 1020 LCD's
I happen to like Viewsonic. These have VGA and DIgital. The 24in also has HDMI and seems to support HDMI "PC" and HDMI "AV" at least these are different selections. Since this is primarily a PC monitor vs a TV, it should have correct sync for a PC HDMI, although I cannot test since my present PC does not have HDMI, only DVI.
I think 2 1980x1080 units would allow you to run the various applications on their own portion of your video real estate.
For budget purposes, my 24in unit is a VX2433WM, cost was $210 at TigerDirect.com
John McGaw
The price of largish flat panel monitors is at an all-time low. You could buy a pair of VA2323wm Viewsonic 23" monitors for $380 on any given day and possibly for as little as $340 if one finds a rebate or sale going on. Given their 1920X1080 HDTV resolution they would have room for a multitude of windows and documents at one time. There are often sales on 24" monitors at places like Tiger Direct and Newegg for about the same price. If I were starting over and really needed the screen real estate I'd probably consider a pair of 23" or 24" monitors as a good starting point.
Larry In Lima
I use my 47" TV that way, and it's great. Wife loves checking her email from the couch too.... Larry
