Re: Question on curved parts....
Dave Paine
I have been practicing for my own project which is a curved front display cabinet. I need to replicate an original piece, which is in dire shape.
I do not want to build a steamer, so have been trying laminate vs cut from stock.
Laminate will work, but you have to allow for some spring back. The thinner the laminates, the less the spring back.
I also cut the curve on the bandsaw. Getting the cut piece to be smooth is the challenge. I would not attempt to sand. Too time consuming. I would spend the time to construct a template and then use a pattern bit of whatever length is needed to get "closer" to final shape. For my curve, I get smooth with the grain, but last portion is against the grain so would need finish sanding after this operation.
If yield was not a concern, I would make from laminates. Cutting thin strips does waste a lot of wood.
