Powermatic 701 Mortiser Problem
awleonard
I must seem a like a guy that whines a lot! Really I'm not! I'm not really very picky about my tool setups and such - and that causes me problems! anyway, I have the Powermatic 701 mortiser. I've had it for a couple of years but realyl haven't used it a lot. I have noticed my m&t's not fitting just so. I always make the tenons fat and fit them by hand, so I assumed I was off there. I decided to take a look at the mortiser and the tenon jig (Delta) just to see if there was any error there. My tenon jig seems to wobble a bit - haven't addressed that yet (its next). I put a square on the bed of the mortiser and checked to see if the chisel was square to the bed - it wasn't. I did all sorts of things to make sure it wasn't me or the chisel. The darn thing just ain't square! I fiddled with the ways that hold the motor to the post but that didn't get me anywhere (they can be adjusted to cock the motor a little). So, I decided to shim the post mount. I started with 1 layer of business cards (not good shim stock - I know). That definitley brought it closer. I did a little research and found out mine wasn't the only one. Made me feel a little better that it wasn't just me. I'm frustrated that something so simple wasn't done right. No biggie to fix, but gosh. Anyway, I'm going to try and get it as "perfect" as I can and use some better shim stock (I use cheap feeler gauge sets sometimes. Next, I'll check that Delta tenon jig. I can't recall exactly what I thought felt funny last time I used it, but I made a mental note that it didn't seem exactly right. I had to move the bar over to fit my new saw, so maybe I need to start there.
The new project is a couple of lolling or Martha Washington chairs. Similar to what Norm built. Several m&t's on each chair and with all of those angles, I wan't things to fit well and be sturdy.
Anyway, if you have a PM701, it's somethig to check.
Tony
