OT - Ariens Sno Thrower Problem
Robert R. Clough - Thorncraft
This is not a serious preoblem, but rather annoying.
I purchased the machine in Non, '06. It is a self propelled 24 incher with a Briggs and Stratton engine. Now, the problem is that the elec start has never worked properly. (Thankfully the pull start works well) The starter just whirrs and obviously does not engage the flywheel. Well, usually. Once in a while it will work properly - about one in ten times.
I was told that it was low voltage. Ok, but we have had our main lines redone on the road and I have a large enough box. Then I was told that it was the ext cord - well, I'm using a 25 ft heavy duty, 15 amp cord. I use that length as the machine lives by the house and the cord must run into the cellar.
I e-mailed Ariens which was not useful. They said to take it back to the dealer. The dealer said, when I first brought it up to him, that it had to be the voltage and nothing else.
Any suggestions?
Re: OT - Ariens Sno Thrower Problem
Bill Howatt
Take it to the dealer and plug it into his outlet and give him a demo. However, you might want to get a voltmeter and actually measure your outlet voltage just to be sure it is within spec.
If it is whirring, assuming it is whirring at the correct RPM, then it sounds like whatever is supposed to engage the crankshaft is sticking.
Bill
Dave Bair, Eaton Rapids, MI
Sometimes, rapping (not beating) the starter motor with a ball peen hammer (or a metal rod if there's no room for the hammer) will free the spring-restrained gear most of these little motors use. Try it first while the motor is off. If that fails, try it with the motor running.
Re: OT -  B & S engine problem
Al Stokka - Cambridge, Iowa
Robert,
Starter motor spins but does not crank engine:
1. Sticking pinion gear due to dirt (likely your problem),
2. Damaged pinion or ring gear (NOT likely yor problem since the starter works somethimes) or
3. Incorrect rotation due to reversed motor polarity - all motors turn counterclockwise (NOT your problem).
Can you remove a cover and observe the starter pinion while applying power (electricity) to the starter? The pinion should move away from the starter motor. If it doesn't, remover the starter and clean the shaft on which the pinion is mounted. DO NOT lubricate the shaft or pinion.
Al
Bendix drive gear
Grant in Iowa
Robert,
Sounds like the bendix drive gear to me. This is the bit of mechanical wizardry that throws the starter gear into the flywheel gear teeth when the starter button is pressed. Equally importantly, it disengages the starter motor when you stop pressing the button.
I believe the strategy is to unbolt the starter from the motor to access it, clean the gear and lube with a special grease or lube. DON'T grease it with just anything, as that too can cause issues. Ask your dealer or look online for the right stuff to use. Not sure about what to use on a Briggs, but the Kohlers have a special lube spec'd in the maintenance manual.
It should be easy enough to proove/disprove your voltage issue. Just drive the machine to somewhere close to your main panel and plug it in and try it.
FWIW,
Grant in Iowa
Bill Grumbine (Kutztown PA)
I don't know the model of my Ariens offhand, but I had a similar problem. The starter motor gear was all chewed up. Every now and then it would catch just right and start the thing, but most of the time it would just make noise. I had to replace it, but it was worth the money. Most of the time mine will start with a pull or two, even for the first time of the season, but there are times when it won't start for anything unless I crank it with the electric starter. Now if I only had one for the generator. I thought I was going to have a stroke before I got that thing started.
Re: OT -  whats a snowblower
Jerry Gibbs
left my snowblower in MI. I'm in FL. Cold enough to whine, but no show in the Sarasota area. Jerry Gibbs
Jim
I'm not sure that B&S had a spring on their starters, but what they do have is a fiber washer that gets worned or chewed up that will keep the gear from engaging the flywheel. The fiber washer is used to keep the gear drive from being destroyed.
On most ariens snowthrowers, there is only a few phillips head screws that keep the entire shell from coming off.
Once inside and with your hands well out of the way, attempt to use the starter. If the starter gear is not worn, or teeth broken off, and the gear drive attempts to engage, but doesn't engage all the way, pull the starter off.
Once the starter is off once again attempt to engage the starter, if the starter seems to run at a reasonabe RPM, check between the starter motor and the gear for a larger plastic or fiber washer. If it is not there, get the part # and replace it.
By the way, the gear is easy to remove from the end of the shaft on the starter motor. I have replaced many of these washers and it usually corrects the problem.
Thank you all very much. I'll almost certainly wait for warmer weather but at least now I know what to do.
