Cutting Magazines on the tablesaw...
Rob HIx - King George, VA
Hey all,
I have a lot of old magazines that I want to keep the articles in, but they are taking up too much room in our small house. I have been scanning them as I get time, but pulling them apart and cutting the pages down to fit in the scanner is becoming a much dreaded chore. I am wondering if it is safe to do this on the tablesaw.
Here is my idea. A couple pieces of plywood larger than the actual magazine. Put several magazines between the piece of plywood and secure them with a couple of bolts (with countersunk heads) on the side where the cut is to be made to compress the magazines. Then, set the fence to the width of the plywood pieces and !zing! Cutting made easy.
Of course I know to be careful of staples and the like in the binding of the magazine. I don't see this as being much different from cutting MDF. Any opinions on the safety of this?
Thanks is advance,
Rob Hix
Re: Cutting Magazines on the tablesaw...
While the TS might work it certainly puts one of those "maybe this isn't a great idea" thoughts in the back of my head. Perhaps the band saw would at least be a safer approach?
PS...of course a chain saw would be the most exciting approach. ;-)
Alan Young
i agree with the band saw aproach
Alan Young
Gary Smyth
No!
Tell me what happens when one of the magazines in the middle of the pile slips just a little and the pages in the pile start to fan out, start to catch the spinning blade, causing the whole mess to skew? I'm thinking that in less than the blink of an eye you have a multi ounce wood frame kicking back at 200 miles an hour, ripping the whole thing toward you.
This would be a good trivia question. What is the resistance of a single page of magazine coated stock to a table saw blade? Multiply that by the number of pages and the number of magazines. I'm confident it will be greater than wood. Wood at least won't move between laminations.
A band saw will be safer but kiss the blade goodbye after a short amount of time. Magazine paper is coated with clay, that is why shiny magazine pages are so heavy. It would be similar to using a band saw to cut drywall (almost)
Printers do not use a rotating blade to cut piles of paper. They use a guillotine slicer. It cuts on a skew a few pages at a time--like tearing a telephone book. Take your magazines to a printer and get it done. He will place the magazine, set the limiter, apply the hold down, cut. It's a five second job. You can also buy a used small guillotine paper trimmer on ebay or other sale area, it will easily cut a magazine thickness smoothly with a good blade. It will be accurate but handle fewer pages than a printer's machine, but it will work.
Re: Cutting Magazines on the table saw...
I agree with Gary and all of the above. This might work, but it has the potential to be a giant screw up.
Check around for a local printer that does binding. Binding may be done by a different shop than printing. They will have a shear. Poke around and find someone willing to shear the spines off the mags. They will have done it before. The printing industry is suffering along with the economy and you should be able to find someone to treat this as a side job and do it cheap.
PS, I found a large stack of blue paper and needed it for binders or covers. I tried cutting it on the TS. My best blade left it ragged.
Alexandre Grigoriev
Are those names defunct? Could they be available on CD/DVD by now, so you don't have to waste your time? Even though, for example, $150 for complete Fine Woodworking may seem a lot, it's still worth the hassle you'd have scanning those.
I'd do it...
John in NM
Provided there were no staples and I could use the bolts to clamp it nice and tight. Probably cut an inch or so stack at a time, between a couple pieces of 1/2" plywood. Doesn't sound near as scary as cutting plexiglass or making a plunge cut.
But the bandsaw would be fine too, nice sharp blade and I doubt you'd notice much difference.
Worrisome
Bill Tindall
If you must, use a something like a 40 T 7 1/2" blade, narrow kerf. A cheap framing blade will do. I think you want very non aggressive teeth.
What I am concerned about is the teeth catching the loose pages and yanking the magazine into the blade.
a band saw sounds much less worrisome to me.
Rob Hix - King George, VA
Well, consensus here is that it is too dangerous. I kinda had that feeling in my gut. I guess I will learn to trust that feeling.
I will look for a guillotine cutter of some type. I can continue to use the rotary cutter until I find the other. It will just be REALLY slow going.
As for having the magazine digitally, most of them a Woodsmith and ShopNotes. I do not see an option on either of their web sites for electronic versions.
It will eventually get done.
Thanks again,
Rob Hix
Another thought......
You might try using a plywood blade and turn it around backwards. That's how some people cut vinyl siding. Works on vinyl. Try one and work your way up. Try a 7 1/2" cheap one as Bill suggests.
Any printing company should be able to do this for you. Where I used to work the trimmer could slice through several reams of paper at once.
a contrarian point of view
Gary Camp, Bend, Oregon
How much is your time worth? Would it make more sense to buy a bigger scanner?
glc
Lee Gordon
Lee Gordon
If a band saw isn't practical, how about just trying a jigsaw.
pecker
I would think that with a straightedge and a sharp utility knife, you could cut through a magazine in about 2 passes of the knife. Take maybe 30 seconds.
The straightedge should be the type with a handle so you could bear down hard on the magazine.
