Re: Performax Belt Tracking
Grant in Iowa
I would propose this:
There are three reasons the belt might tend to move towards one side:
1. driven head of the machine isn't parallel to the INFEED roller.
2. Belt is not made right
3. tracking roller (oufeed roller) is out of adjustment via the tracking screws.
The manual (like many) assumes that #3 is the only solution, and I would submit that, if you have exhausted your patience adjusting the tracking per the manual, then the trouble might be either #1 or #2 above.
You would need to make a jig to check #1, but it could be as simple as a single piece of sheet stock cut to both hook over the infeed roller and to allow a feeler guage to check the distance between that jig and the driven sanding roller. I do not know wht the acceptable tolerance should be, but it seems to me that a real issue in this area would be pretty apparent. I know on my 10/20 you can adjust this parallelism by loosening bolts that hold the head to the table.
So if your belt tracks nicely until you run a board through, you might want to check this parallelism.
FWIW,
Grant in Iowa<---if I had more time I'd draw the jig I propose
