Marking Dark Wood
Marking Dark Wood
Marking Dark Wood
Ken Bellock (Houston, TX)
I usually work with oak, and use a pencil to mark. It's easy to see on oak, and I use it for labeling parts, triangles for gluing up panels, and for sanding. When sanding I put diagonal lines all over the surface and sand till they are gone, then it's time for the next grit. I use awls and knives to mark joinery. I'll be working on a project this weekend that will be using walnut. What is a good substitute for marking dark woods for these purposes that will not affect the finish? Does chalk do a good job, or is there something better?
Re: Marking Dark Wood
Lee Grindinger
A white pencil
Lee Grindinger
Really. They make them and they work well. Art supply or office supply stores should have them.
Lee
Re: A white pencil
I am fortunate enough to own a bunch of walnut. I use chalk a lot. It was harder to find than I thought it would be and I ended up with a box with about four colors. Turned out the colors are useful. Code stuff. Different colors for different things. I also do the same thing you mention with the chalk and sanding. Scribble on it and then sand the chalk off. When you finish, Inspect closely and blow the dust off. I have never had it happen, but it would be bad for the pink and chartreuse to show up as grain filler.
I also have a white pencil and like that. And I sometimes put pieces of blue tape on parts and label them.
Re: A white pencil
The wife is out running errands, including a stop at an art supply store. I sent her a txt telling her to pick one up.
Thanks for the tip.
Re: A white pencil
Carol Reed
Also available in fabric stores. For dark fabrics. Different media, same solution.
I use chalk
Lee Schierer McKean, PA
I use chalk to mark all my parts. I've never had an issue with sanding or finishing due to chalk. In fact you need to handle parts with some care or you can wipe it off.
Lee
Another color I like
Gary Camp, Bend, Oregon
I get silver pencils at our local NORCO welding supply store. They seem to work well also, but a bit soft
glc
soapstone?
Jerry Gibbs
Just bought some soapstone for use on metal, but it could be sharpened to a point if needed. No experience on how it comes off and am interested. Jerry Gibbs
FredD
White Chalk like school kids used to use on the blackboard or Lumber Crayons are typically used for what you need.
FredD
Blue pencil or blue ink show up well on walnut.
John Pappas
Couple things about white pencils
Art supply stores sell two or three different kinds of white pencils and some are softer than others, so you might want to get one of each and see which works best for you.
I found that I need to be careful with white pencils on porous woods because the pigment can get packed into the pores. If you're on your final sanding with 320 or some really fine grit, you might find that you need to switch back to a lower grit to get rid of the white. You'll figure this out soon enough.
Thanks
Picked up a white pencil, and some chalk in a couple different colors. I will try them both on some finishing samples first to make sure there will be no issues down the road.
Thanks for all your advice.
Ken
Re: Couple things about white pencils
Dave Bair, Eaton Rapids, MI
The concern about porous woods also applies to chalk. Use only white or yellow chalk on oak, ash, etc. I've tried blue, green and red and had to sand mercilessly to get down to the bottom of the pores. White and yellow disappear if I use an oil-based finish or shellac, even when they remain visible in the pores after normal sanding.
Black or blue gel ink pens
Bill Tindall
It dries to a reflective film that shows up brightly on walnut in good lighting. Find a brand that doesn't wick on wood. Pilot has traditionally been good for the task.
