We value your privacy.
"Install a 3/4" or 1/2" thick board cut a width that would project below the crown about a 1/2" or a little less and then run your old crown on that , which will need a little shortening, but a much easier way to go and you have the added advantage of it looking more like a professional crown job with the added detail which is a common way to install crown molding."
I'm about to put up some simple crown molding and would like to make it look as you say "more like a professional crown job". I'm having a hard time visualizing what you are suggesting. Since I might not be the only one, can you provide a little detail on how a professional might do the job?
I found some base molding that had a profile that would complement the crown. For me, one of the issues with crown is finding the studs to nail to. I took the base molding, turned it upside down and then nailed it on the walls with it spaced down the right amount to match up with the crown. See the sketch
Now that you have the idea, you see that there are endless possibilities. I did a room for a friend that had ten piece molding. I could not even begin to draw the arrangement, but it was a bunch of stock molding, layer upon layer. about four on the ceiling and six on the wall.
Another idea that was popular around here for a while was to do the molding as in the sketch and then drop down about 1 1/2" and run another small molding around the room. Then you can either paint the stripe of drywall that is left exposed to match the molding or a totally contrasting color.
Dont let the use of the word "Professional" throw you , though I did many complicated Crown and Frieze mouldings specified by Architects, they could draw the profile , but couldn't do it .;-))
The ten piece or whatever Barry mentioned is a Frieze and all of the Architectural detail you may see in upscale homes and and Public buildings are descended from Stone buildings as in Ancient Greek and Roman Public buildings.
Dan has provided a sketch that should give you a good idea of what we are talking about .
You will notice that he has brought the bottom edge of the Crown molding down close to the upper edge of the inverted base board he used for the bottom strip thereby making a Fillet which if you do it in a tight fit , becomes a one piece molding to the eye.
If you wish I can scan Bay Panel and Molding catalogue which was a company I ran work for and they created their own molding profiles whcih are the best I have ever seen..
Much more of a custom look then the Western White Pine knife profile catalogue Architects typically used.
It would give you a excellent view of simple cove and crown right on up to huge Friezes which generally you wouldn't see in a modern home with eight foot ceilings.
But if your ceilings are sixteen feet and over in height .............;-))
