Need recommendation on wheel set
Ralph Lipeles
I have a nice router table that I built this summer and would like to add a wheel set to make it easier to get it away from the wall when I am working on longer stock. The table has 4, 1 1/2" square corner legs that are spaced 20", front to back and 40" left to right. I would appreciate any recommendations on purchased or homemade sets.
Thanks in advance,
Ralph Lipeles
Re: Need recommendation on wheel set
Re: Need recommendation on wheel set *LINK*
Galen Vetterick
I purchased three set of these lockable wheel sets from Rockler and put them on my Jet 1220 lathe stand, 10" table saw and small 12" band saw.
All roll easy on concrete or wood floor and lock to be stable.
The Sale price is hard to beat.
The 1/2" threaded is not 12 threads per inch but standard 13. Told Rockler but they will not change data.
They have the same set in 3/8 theaded but not on sale. Those were the ones that fit my lathe stand.
If your legs are wood just drill and install tee nuts so they thread into steel.
Galen
http://www.rockler.com/product.cfm?page=11182&filter=casters
Clint Searl
Clint Searl
I think I'd mount wheels on 2x4's, hinged to the legs across the short sides, that could be swung up when the table is in use.
Clint
Ralph Lipeles
Clint,
Sounds like a simple,,easy to implement, approach. How do you lock the 2x4's in place?
Thanks,
Ralph
Clint Searl
Clint Searl
Ralph,
Here's what it would look like. Side view
Clint
Ralph Lipeles
Thanks Clint. It looks pretty simple. All I have to do is be careful to position the hinge pin a little bit up so it sits on the leg rather then the hing pin when not on the wheels.
Ralph
