OT Paint removal question
I have a old Jenn Air Range. The black paint on the control panel is failing from heat, age, grease, whatever. It would look better if I removed the paint. I don't need much. Only have two patches about 3" X 3" to get off. I have gently scraped some of it, but that leaves scratches on the stainless steel. What can I use to take it off? I need a tiny amount.
Re: OT Paint removal question
Jorge Casta�eda
Barry,
try a heat gun and steel wool, easy with both.
del schisler
any good paint remover should do that job I belive steel wool would scratch surface But if you are goint to paint again Shouldn't be any trouble Base paint than the over coat
