OT - Repairing stone fireplace
Stephen Kirk
The base of our fireplace suffered a break yesterday. The fireplace sits on a stone base set up on brick, with a bit of overhang. We lost a u-shaped chunk of the stone about 12" long and 3" deep. It's not a structural element, luckily.
We have the pieces that broke off and they go back together pretty cleanly with little joint line showing. The broken pieces are 2 large chunks a few small pieces. Is this an easy DIY fix or am I better off calling a mason to make sure it's done well? I've never done stone work that didn't involve a shovel and wheelbarrow, so I don't know what I'm in for.
Thanks,
Steve
Re: OT - Repairing stone fireplace
I am not a mason and don't know if this is a good idea, but I have seen a number of people use clear epoxy to glue bricks back onto their steps after they fell off. It was the classic brick missing from the corner thing and they still had the brick and it fit perfectly, so they just coated it with clear epoxy and pressed it back into place. The "trick" is to carefully coat the surface and fill all the voids so that water does not get into the joint. If water leaks in, freeze thaw action will pop the brick back off.
It might work for you if you can figure a way to hold the stones in place until the epoxy sets. Also, the stones and joint must be dry and warm for this to work, so you may have to wait until spring or set up a heat lamp.
Dave Bair, Eaton Rapids, MI
You might try the "Brick and Concrete" exterior glue in a tube sold at the Big Box stores. I used it on a low retaining wall and it has held up through 5 Michigan winters. If your piece is subject to significant heat, you'll probably have to try something else.
Stephen Kirk
No heat, just the the stone base the whole mantel sits on. I'll check it out.
