Sightings Pic....
John L Blue
>Lignum? um, got stuff lookin' like that by this lake here in nc, never figured out what kind of wood it was, it's abundant, twisted, I've got crazy lookin' walkin' sticks from it, reckon it's around here also.
Sightings Pic....
John L Blue
Lignum vitae
>The trees you're seeing in North Carolina are not likely to be lignum vitae because it is a tropical tree. I'm curious, though. If you send pictures of the look-alike you mentioned, maybe we can ID it for you.
Ellis Walentine, Host
Just been some turning Lignum Vitae
Louie Lovas
I just turned a few mallet heads of Lignum Vitae this weekend. I've read that it's the densest wood on the planet. While it dulls chisels quickly, it does turn quite nicely. It's a very oily wood too. The shavings (if you can call them that) are very cakey. If you grab a handful and squeeze it clumps together - a sign of the oil content. Smells nice too! In the photos below the darker color originates from Mexico, the lighter one is from Argentina. The wood makes great mallet heads. It sands to a fine polish (400 or greater grit), and no finish. The wood's own oil content is enough to give it a nice sheen. It does have a tendency to get fine hairline cracks, however I've never seen this affect the wood structurally.
What are your intentions for all of those?
Gary Smyth
Re: What are your intentions for all of those? *LINK*
Louie Lovas
I will be putting them up for sale, I have about 25 in total. They are a whole variety of wood species. I'm not quite done with them, you can check out my progress on my website.
http://www.flinthillfurniture.com/inprocess.html
Lignum vitae finishing trick
Lignum doesn't do too well in temperate climates, because it's impossible to kiln dry and it will check badly in low relative humidity. Back in the 70s, I learned a trick for finishing lignum vitae mallet heads to prevent this. After you've turned and sanded your mallet, melt a block of paraffin in a saucepan. [Note: Do this outside on a hotplate and be extremely careful. Hot wax is very flammable.] Next, heat the outside of the mallet or workpiece with a blowtorch, moving the torch around the piece so it heats evenly all around. Don't char it. Soon you will see a reddish-brown resin start to bubble from the surface of the wood. Keep heating until the piece is bubbling all over, then plunge it into the molten wax. After it cools, remove the excess wax and hardened resin with coarse steel wool. Presto!
other finishes?
I've made some things from lignum vitae - smaller turnings, wands and pens. Finished one wand with a shellac friction polish and a pen with CA glue. Both seem to have done OK, but is there a recommended finish for small things like this? Not sure about torching and dunking the pen parts into hot paraffin! One person recommended foregoing any finish and simply polishing the bare wood.
BTW, I think it's recommended to melt paraffin in a double boiler instead of a saucepan directly on a hot plate. For a good demonstration of how easily and well hot paraffin burns, try melting a bit in a big spoon over an open flame. (again, outside)
Re: other finishes?
I used to make various wax polishes, and a single boiler works fine. You just need to be careful.
If you want a film finish or an oil finish on lignum, you're welcome to try it.
Re: other finishes?
>...you're welcome to try it.
I've tried some, I just wondered if someone had some long-term experience with various finishes on lignum vitae, whether some finishes are likely to fail over time.
For example, I found out that applying oil to cocobolo may not be a good idea - I made several identical items once and tried various finishes - the one I put Watco oil on slowly darkened until a couple of years later it was as black as ebony. Another with a shellac friction polish still has most of it's original color.
The pen I made from argentine lignum and finished with three coats of CA has turned a wonderfully beautiful green in the last few weeks.
Something I've thought of doing and haven't gotten around to yet - turn cylinders of various woods and apply different finishes to sections of each and see how the wood changes over time. It would be best if I could find pieces that included a strip of sapwood down the length.
Interesting Stuff
It was the original self-lubricating material (now replaced by Teflon and such). It was used for shaft and propeller bearings in steamships for 100 years. Replaced by sealed bearings.
Carved a piece in it once. With constantly having to sharpen my chisels, I think I wore a good 3/8" off their lengths doing that piece. More like carving stone than wood.
Re: Sightings Pic....
Don Orr
John-a possibility for your twisty stuff in NC is Crepe Myrtle. Pretty common down your way. Pretty tree, kind of crazy looking though. Nice flowers. Saw several of them at the Orton Plantation near Oak Island last year. But lots of tropical plants have been cultivated outside their normal ranges so who knows.
John L Blue
It's not Crape Myrtle, I'm gonna post a pic of it in the near future, appreciate it, tho.
