Long Term Lumber storage questions.
>I have several thousand feet of walnut and cherry we cut off the family farm. It was mostly cut to 1" with some 8/4 and some 16/4. It is stored on stickers in an open barn in Virginia. We did not treat the lumber in any way other than we sealed the ends of the logs with Anchorseal.
My questions are about long term degrade. The wood does not get rained on and remains dry, but will insects attack it? What else do I need to know or Do?
Re: Long Term Lumber storage questions.
Bill Tindall
>By now you are certainly aware that beetles may attack the sapwood of both species and if they are hungry get into the heartwood some.
Another consideration is dirt. The dozens of stacks of barn stored lumber I have looked at (until I tired of it) were invariably covered with a layer of dirt. Barns seem to be a magnet for dust and it deposits on lumber piles. I would suggest some sort of loose cover over the piles.
>Covers might be a good idea.
Do you think it would be worthwhile to spray a couple of gallons of Bora Care on the stacks? I don't have the energy to take the stacks apart.
The lumber is piled on top of about two feet of compacted sheep poop. Aren't farms great?
I'd add this.
Forrest Addy
>I'd add this:
The closer the stack is to the ground (or sheep poop) the more likely it is to pick up moisture and bugs. I suggest concrete blocks under the stack and maybe a poly sheeting in the ground under the stack. This is kinda important if you have a wet season. Also cover it as you were thinking with something porous so moisture can escape.
In my neck of the woods, I've seen a few tragic cases of stack rot and borer infestations where someone's grandpa milled up a couple of Mbf and stacked and stickered it in dry shelter for a few years. A few years led to a decade or two and the lumber was shot except for the top few boards. I could tell you some tragic stories.
If the lumber you so laboriously cut is stacked only a few inches off the sheep - um - debris remember that sheep debris poops out, decomposes, and weight of the stack will push whatever have it stacked on into the crust leaving the stack flat on the groumd. At the risk of making more work for you I strongly suggest you re-stack the lumber some distance off the ground (8" min I would think) in a place where there is no decomposing sheep debris to hoard moisture and harbor bugs.
Dick Coers
>I'd say you have set up the perfect buffet for powder post beetles. You'd didn't mention if the wood was dried, but I assume it's not. The air drying will take longer inside the barn, so the beetles can hatch out, and relay eggs to keep the cycle going. I did a quick google on preventing infestation, and they all mention borates. Is there a haymow? It would be warmer up there, and better drying conditions. I know lifting wet thick stock up there sure won't be any fun, but maybe better in the long run.
Don't forget pigeon poo prevention too. I was called out by an old friends wife after he had died. She wanted me to go over the stacks of wood in the barn and help her set a value. There must have been 2" off poo on top of some of the stacks. Racoons had also set up poo areas. After watching "Dirty Jobs", and watching them suit up to fight pigeon poo, I didn't want to get close to those stacks. There are long list of diseases that you can get from that!!!!!!!
Cover ups
Tom Dunlap
If you have a lumberyard nearby I bet that you can scavenge some of the sheet material that wraps the loads. It is heavy duty, free and you'd keep it from becoming waste.
If you cover with tarps or plastic make sure that you don't make a greenhouse, trapping moisture inside. Wrapping with a Tyvek type sheeting and then making an inclined roof, with drip edges beyond the pile keeps water from standing on the pile.
sell it
Bill Tindall
To be blunt, if you aren't going to store it in a way that will ensure it will be useful years hence you will be better off selling it and buying what you need when you need it.
If it is sitting on the ground the bottom layers will at least mold if not rot. If you are unlucky bugs will find it and turn the sap wood to dust and may penetrate some heartwood. If it is not stacked properly it will not be straight when you need it. Etc.
The lumber is 3 years old....
Stacked on pallets so it is about four inches off the poop. The poop is many years old and seems to be in about the same condition it was in three years ago. Wish I had had a better place to store it, but I am glad I had what I did. This is in a shed on the side of the barn and it is open and on a windy hilltop. Not aware of any rain ever getting onto it and I don't think er is any pigeon poop. there is pine lumber laying on top of most of the piles to serve as weight. That's keeping some of the dust and debris off the piles.
I have some really crappy walnut in my shed that a friend of my father sold me when I was in high school. It was crap when I bought it and it is still crap. Much of it has shakes in it so bad that the pieces fall apart when you cut it up. But, It has not degraded in all this time. what I should do is throw away the crap and move some of the good stuff into it's place.
Thanks for the thoughts.
This is actually a good thought, thanks
There is more lumber there than I can use in a life time and some of it is going to waste no matter what I do. And, being local Virginia walnut, it has those streaks in it from some sort of bug infestation while the tree was alive. So, I could sell this stuff and buy a smaller quantity of premium stuff for my own use.
Checking account, not savings
Stephen Kirk
What I mean is, store what you can reasonably use and get rid of the rest. I've been rethinking my lumber stores as I know it's not stored well and will degrade on me. So, if you have lots, get the projects going. Bugs don't like planers and jointers. The good thing I like about trying to use up my lumber is that I'm not afraid to waste some wood trying things out. Make panels instead of using plywood.
Re: The lumber is 3 years old....
Several times I have been given or had someone trying to sell to me walnut that has been stored in an open shed or barn for years. Although the owners usually think of it as a valuable treasure much of it has been full of bugs and useless. This makes me doubt the wisdom of storing walnut for a long time.
Some people report success in treating lumber with Timbor after sawing and before storage.
A follow up.?
I'm wondering if spraying the outside of the stacks would do any good. I don't have the energy to take the stacks apart and stack them. I could put the wand of the sprayer between the layers.
Re: A follow up.?
You could research this on the Wood Web. There is a huge amount of information there - check the knowledge base or read some of the threads in primary processing forums:
http://www.woodweb.com/KnowledgeBase/KBIndex.html
I thought ppbs mostly entered through the end grain and if so, spraying the ends of the stack might help, but I don't know. Remember that anything applied on the surface won't do a bit of good if bugs are already in the wood. Also, if I remember correctly there are two different kinds of PPBs - some are principally a problem with green/wet wood but the really scary ones are not.
BTW, I once witnessed ppbs actually entering wood. I was outside my shop sectioning short maple logs into turning chunks when I noticed little black bugs flying around - it looked like they were all flying in from the direction of the woods. As I watched, bugs would land on the freshly-cut end-grain surfaces, fold up their wings, and begin chewing into the wood! I even saw a few digging through a surface I had coated with Anchorseal. I quickly sprayed the wood with insecticide and carefully inspected the chunks for holes the next day. I assume they were attracted by the rather strong smell of the wood. I collected a few and under the microscope they sure looked like PPBs.
Be amazing chance I also once witnessed a ppb EXITING a piece of wood. A friend had given me some 2"x2" spindle-turning squares that had been stacked outside under a tarp for years. I had some on a shelf near the lathe, right about ear level. In a quiet time I kept hearing the strangest little "scritch..scritch..scritch" sounds. While looking for the source I watched a hole open up in the end of one of the walnut pieces and a bug emerge! What are the chances? - that bug may have been chewing it's way through that piece for several years. I got rid of that stack right away!
