Glue clean up
Glue clean up
Glue clean up
>I've watched Norm Abrams for years just because he's fun to watch and it makes a good lunch break from the workshop. Norm always wiped excess glue off with a damp rag. Today I was watching the American Workshop and Scott Phillips scraped the excess glue off and said "I never use water to remove the glue". That had to be in reference to Norm's method.
Well I've done both over the years including waiting for the glue to start skimming over before scraping it off.
Is there a prefered method for this? does one have an advantage or dissadvantage? Where do you all stand on this?
Re: Glue clean up
Re: Glue clean up
FredD
>I use all three of the methods you mentioned, plus taking care not to let any squeeze out if I have the time in the assembly.
All of the methods work and I generally use the the easiest ,depends on the location of the glue and how hard it is to access.
About Norm and his gluing , I like his work methods for the most part , he has a knack for teaching woodworking, but I never found it necessary to brush on the glue, simply sliding the parts back and forth one time will do all of the spreading needed.
FredD
Re: Glue clean up
Depends on what I'm gluing
John in NM
>I mostly pre-oil parts then glue together. Squeeze out pops right off once dry. I'm less picky with joints that will be planed or sanded flush after glue up, or when I'm using hide glue.
Re: Glue clean up
Re: Glue clean up
>Typically for yellow glue or hide glue, I use a toothbrush and warm water followed by an immediate wipe with a damp rag. I've got to sand or scrape to get the alignment marks off, so a little water doesn't hurt.
Re: Glue clean up
Re: Glue clean up
charlie belden
>Michael Fortune found dealing with glue squeeze out when doing windsor chair to be more work than making the parts for the chairs. He found stuff called Waxalit and solved his problem. Stuff comes in a small can and has the consistency of Renaissance wax. Apply it with a Q-tip where squeeze out is expected, let it dry and do the glue up. Any squeeze out can't stick to the Waxalit treated surface and pops right off. Some alcohol on a Q-tip wipes the Waxalit off - leaving a surface that will take your finish - without discoloring, or not sticking.
Waxalit is available from Lee Valley.
Re: Glue clean up
Re: Glue clean up
>It would be good to know the proper method, if there is ONE proper method.
I have taped off joints with blue tape. The timing on that is important. If you pull it off too soon, the glue gets on the wood anyway. If you wait too long it glues the edge of the tape to the wood and its about as hard to get off as if there were no tape.
I have used water to clean up. You have be really thorough or you will scrub the glue into the wood and that screws up the finish. Norm looks pretty casual about it to me, but I thought it was just TV magic.
If you use a card scraper on and inside corner you can tear up the surface easily because one side of the joint will often be cross grain to the other.
Re: Glue clean up
Clint Searl
Re: Glue clean up
Clint Searl
>More expense and trouble than it's worth. Wet paper towel is all that it takes. Squeeze out means too much glue, anyway. Norm, would probably say I starve my joints, but I've never had one fail.
Clint
Re: Glue clean up
Is washing harmful?
Bill Tindall
>I stain most everything I make and always feared that washing glue off would just drive it deep into the wood and then it would mess up staining. Is this fear unfounded? Additionally this extra water will slow the joint cure and swell the joint area which can be a problem.
For edge gluing, where there is always squeeze out, I let it dry before dealing with it. If it is partially dry I will scrape it off with a putty knife. Otherwise I just run the glued panels through the planer and the glue goes away.
For mortise and tenon, and the like, I try to avoid any squeeze out. If I do get a tiny bead I wait for it to dry and cut it off with a chisel.
Re: Glue clean up
Re: Is washing harmful?
Jesse Cloud
>I think there is reason to be cautious about that wet rag. You wind up spreading a diluted coat of glue (a glue size?) all around the area, which will not take stain the same way raw wood will. For applications such as edge gluing, where you will probably be sanding or scraping anyhow, it doesn't matter much.
Curiously, I once knew a woodworker trained in England. She applied a thin glue size to the entire workpiece to ensure an even stain penetration. Different ways to skin a cat...
Re: Glue clean up
Re: Glue clean up
Dick Coers
>I let the glue just firm up, and then cut it off with a chisel. If I am edge gluing I use the same method. I was taught that if you let the glue harden on a glued up panel, then scrape it off, then machine it right away, you run the chance of having the glue line shrink as it dries deeper in the line. I also believe that wiping with a wet cloth will fill some pores with glue. I've always thought that Norm uses about 5 times too much glue. A little squeeze out is a very fine little line. If it's running off the boards, that's way too much. Norm has been a great influence for hobby woodworking, but he was a carpenter that started making furniture. Some of his techniques are not the best. (No hate mail please! ;) )
Re: Glue clean up
Re: Glue clean up
Jim Dillon
>John,
Like others, I use the method that seems to best suit the application. Here is a tip that IIRC came from the makers of Titebond adhesive. Use a slightly damp green abrasive pad to wipe up the glue. The abrasive strands seem to grab the glue and lift it up and away from the wood rather than smearing it out. Use a fresh surface of the pad every swipe, then rinse the pad and start over. The key seems to be that the pad is just damp and not dripping with water. The method works fine, although I probably use wet paper towels most often because I'm too lazy to look for the abrasive pads :) .
Jim
Re: Glue clean up
Kirk (KC) Constable
I think you have to have a LOT of squeezeout, and do some heavy scrubbing to cause any significant problems. I wipe all the time with a dry towel first, or scrape with an old putty knife just as soon as I've got the clamps tight... then wipe with a wet towel. Doing it while the glue is still wet to begin with may make it less of an issue because I'm not scrubbing as hard as if I'd let it start to set up, which it would seem could drive the glue down into the wood.
Re: Glue clean up
Re: Glue clean up
This has been enlightening. Personally I use a paper towel that's pretty wet. It seems to pick up the glue very well. About the only downside is sometimes it will leave behind little paper towel remnants but these aren't hard to clean up and haven't seemed to cause a problem.
I'm usually doing 2 or 3 things at once so trying to remember to get back to the glue before it gets to hard to easily scrape off just doesn't work for me. For edge joints I just wait until it's dry and use a card scraper to level the surface.
I also use a lot of epoxy on some joints, I clean this up with alcohol or acetone. I haven't had any problems with that. If I think I will get a lot of squeeze out I put a coat of Johnson's paste wax on the area not to be glued. The epoxy pops right off of this and it's easily cleaned off with mineral spirits.
Take all of this with a grain of salt because I don't build very many pieces of furniture. Mostly art type pieces and lots of turning, however I do glue up a lot of stuff before it gets to the lathe.
Re: Glue clean up
Re: Glue clean up
les winter
I use a drinking straw. The large diameter plastic ice cream soda type. I get mine at the supermarket and keep a box of 100 in my shop.
I push the straw along the joint and the squeeze out is drawn up into the straw. Then I blow out the drawn-up glue into a paper towel, and do some more. This works very well on panel glue ups right after clamping. I don't like planing dried hard big glue squeeze out globs. The straw method avoids this.
If I cut the straw at an angle, I can get into tight places.
BTW: I have not tried sucking on the straw.
