Deal on 1" LT carbide Resaw King Bandsaw Blades
charlie belden
>A member of the Robland X-31 Owners Group on Yahoo sent out e-mail to
members about a deal Laguna Tools is running on their carbide tipped
Resaw King bandsaw blade. This is a close out of their 1" Resaw King version
#1, 3 TPI. bandsaw blade (there's a New & Improved Resaw King - that's band is
0.06" instead of the 0.08" of Version #1).
So, for the V1.0, One Inch Only, blades - up to 180", the price is $75 each.
The Resaw King ran about $3.50 - an INCH - and I think the New & Improved
is closer to $4/inch.
This blade is designed for slicing veneer - and DRY wood, so wouldn't be
suitable for slicing and dicing green logs (2 or 3 tpi hook tooth with DEEP
gullets work nicely for green wood). But if you resaw dry wood - this is
a real deal on a very good blade.
I've lusted after one for years, having seen it cut at several woodworking
shows. At this price point this dream will come true (and arrive in about
four days)
So if you want one
1-800-234-1976 ext 9617 and ask for Tim Lorey
Tell him charlie sent you - via Chris Larime
I have no affiliation with Laguna Tools other than owning
a Robland X-31 and an LT 16SEC bandsaw I bought from
them 8 or 9 years ago.
Re: Deal on 1" LT carbide Resaw King Bandsaw Blades
Brent Smith in Montreal
>Thanks for the info Charlie. I just placed an order with Tim. I've had one on my saw for a couple of years now and it does a great job of slicing veneer.
>Can you run this blade on a Delta 14" saw with a riser block?
no
Glenn Madsen---in SF Bay Area
Could  I cut it down with tin snips?
YES.  Put it back together?  Probably Not.
charlie belden
>The length isn't a problem - the deal is for 1" blades UP TO 180 inches - they can make blades up for smaller lengths. The problem is tensioning a 1" blade. Normally the wider the blade the more tension it requires. Whether you riser blocked Delta can handle the tension - maybe someone here can answer that question.
If your saw won't handle the tension needed for a 1" blade, you might be able persuade LT to go for the same deal on a narrower blade. Worth asking at least.
Re: YES.  Put it back together?  Probably Not.
>Charlie, I was joking about converting the blade to a 3/4 or 1/2" balde by "ripping" it with tin snips. That would be a wild ride if you tried it.
I have never bought a carbide tipped blade for the bandsaw. I have ruined several blades in a matter of minutes. Usually cutting bowl blanks that were irregular in shape and offered poor support. Obviously it was foolish to make such poorly planned cuts. Also, I should save such a fine quality blade for the work it was intended for, but sometimes in my shop ....stuff happens.
It's a bi/ch being broke. I better times I would have bought such a blade in a heart beat.
