Semi-OT MDF Crown Movement
Ken Bellock (Houston, TX)
>I was always under the impression that MDF was very stable, when dry, and that movement was negligible. We have a new house that was built a little over a year ago in Houston, TX, in which they installed crown in two rooms that was made from what looks like MDF. When I turn on the heat, in less than 5-10 minutes, I can hear the corners popping apart, and the gap in the miters opens up by as much as 1/16". The one room is an office and is very small, so the runs of molding are no more than 11'. Is it the change in temperature that is causing this, or dry air from the heater. I know if it was real wood it would be completely related to the humidity levels of the air and not the temperature at all, but since it happens so quickly I wonder if MDF, as an engineered product, does move with differences in temperature, or if it just moves quicker than real wood with moisture changes.
These houses were slapped together as quick as possible with caulk as a structural component, by guys who might have picked up a hammer for the first time in their lives that morning, so of course the inside corners that are popping are mitered, not coped.
I guess the followup question would be what is the best way to patch a crack that can move by as much as 1/16" in 10 minutes every time the heat comes on...
