I need shed ideas.
Jason Roehl in Lafayette, IN
>Ok, here's the setup: I desperately need a shed to free up some space in my garage. The last shed I built at my last house was 8'x8', with 8' walls and a low-slope (3/12 or 4/12, I don't recall). Utilitarian, to be sure, but the proportions were not terribly pleasing to the eye. Not to mention, it was kind of an experiment on my part in not having much waste in the materials department.
In my area, I don't need a permit for a small shed (I've heard 300 s.f. and 375 s.f., but I'm not coming close to either). I don't plan to lay any sort of foundation, as the only place I can really put the shed is in a utility easement along the back of my (shallow) property. Instead, I will use the cheap, thin pavers to "float" it on the ground at the corners, after scraping off the sod and compacting the dirt a bit. That way, if the electric or phone companies ever need to dig, the shed could be easily moved out of the way.
Anyway, I need suggestions on proportions. I'm planning on something anywhere from 8'x10' up to 12'x12', with a GAMBREL roof. I've read that the typical slopes on a gambrel roof are 30� and 60� off the vertical. I don't care as much about material waste this time, but I'm also shooting for a budget of about $700, give or take. I'm 6' tall, so I'm thinking the side walls need to be at least that tall.
I guess what I'm after is what dimensions for the side walls and the 4 segments of the gambrel roof will look good for the various base dimensions (8'x10', 8'x12', 10'x10', 10'x12', 12'x12').
Thanks in advance,
Jason
