Laguna Sliding tablesaw wing on Benefit Auction
Scott in Montana
>Hello,
I have listed a Laguna sliding tablesaw attachment on the Wood Central Benefit auction. All proceeds will go to Ellis and the forum.
Thank you,
Scott in Montana
Scott in Montana
>Hello,
Thank you,
Scott in Montana
Holy smokes!
>I always wanted one of those.
Well, anyhow, I'm grateful beyond belief for this incredible donation. Thanks so much!
Re: Laguna Sliding tablesaw wing on Benefit Auctio
>Scott,
Will this attach to any Powermatic 66? May seem like an odd question since if I have one I should know, but I bought a 66 a few years back and it's still in the crate in my storage building! (waiting for shop space). I have a vague memory of the 66 coming in two different width options. I THINK I bought the wider one (50" fence??, some kind of extension table??) but I have no idea without digging through the storage building.
If you don't know, I'll bid on it anyway and see what happens.
I really, really, need to get that shop built. In the mean time, I'm still using a 10" Craftsman portable (head hung low in shame...)
Will fit your 66 and many other machines too.
Scott in Montana
>Hello John,
Yes this will fit your 66. In fact in a private email with another interested party, we discussed the fact that it will fit just about any piece of machinery. The mounting bracket only has to be mounted to the machine's top using the holes that the original wing threaded into and the bottom of the bracket attached to the machine's cabinet via two 1/4" bolts and everything else attaches directly to the bracket. So this should fit saws and shapers from General, Grizzly, and the like. I can't say what the wing bolt pattern is on these machines... it might be the same as Powermatic? Again, the only limiting factor would be if there is a crank on the left side of your machine, it can't extend beyond the front edge of your machine. It would still work if you extended the shaft of that crank a couple inches.
I bought this table over the much less expensive sliding tables such as the models available from Delta and Excalibur at the time not only because of the higher accuracy and good reviews, but because it was very compact. It added maybe seven inches to the left of my saw (beyond the stock wing) and extended out the back maybe 18" which didn't matter because it paralleled my small out feed table. Of course this was with the miter fence turned in parallel to the blade or easily removed.
I was told that this was the sliding table that came stock on all of Laguna's big table saws at that time. I understand that Laguna now offers a smaller stroke aluminum sliding table for the sum of $2115.
Thanks for your interest!
Scott in Montana
Thanks.
>Extremely generous of you to auction this. JKJ
