We value your privacy.
>About a year ago I made my daughter a computer desk with an inlaid formica top. A section of the formica has come unglued - 2 inch section near an edge. I cannot get enough access to reapply contact cement. Can anyone offer a solution for correcting the problem?
>I would try to inject some lacquer thinner to soften the contact cement, then clamp. Of course, you would have to be really careful around any finished wood!
>If you want to lift a section of the Formica so you can get glue under it (Titebond like Dave says will work ) or Contact if you can get it on the underside of the plastic and on the substrate, I have found that the easiest way to release the glue without any damage to anything else is to get a can of lighter fluid and squirt a little under the plastic as you raise it.
It will release the glue bond nearly instantly and because it is Naphtha will flash off quickly.
I wouldn't recommend spraying contact glue unless that was all you had and you could completely mask off the surrounding area, contact glue where you don't want it is not easy to clean up.
