We value your privacy.
>There is a possibility that we may receive the equipment from my father-in-law's machine and woodworking shop later this year. A lot of the equipment (especially the machine shop tools) is rather heavy. In addition, we'll be moving it from California to Colorado. I was curious if anyone had advice on how to go about packing and shipping this stuff? Is it worth building crates for the machinery? If so, any pointers on how to do this? (hire it out?)
>My opinions only. Yes, they are worth crating and shipping.
I would put everything on pallets. Freight companies have forklifts and pallet jacks. Heavy stuff belongs on pallets. There is less chance of it getting damaged. It also makes it easier to handle.
You can box/crate the smaller stuff and consolidate the boxes on a pallet. You can use OSB panels (3/8" thick or so) for your crates.
Strap your loads to the pallet. Shrink wrap is your friend and helps keep boxes on the pallet.
Bright colors (stripes) make your crates more noticeable on a dark truck and less likely to get rammed into by the next stuff loaded.
>I do some crating at my day job, so a few observations. Never use lag bolts to hold something heavy. Always use bolts and BIG, did I say BIG, washers. Also lock nuts or double nutting can help. I am constantly amazed at how bouncing on the highway can loosen anything fastened on a skid. Crates seem to invite forklift punctures. Even 3/4 OSB is no match for a bad forklift operator. Only distance from the edge of a skid to a critical object will limit fork damage. Provide forklift access from any side. In my opinion, a forklift operator would like to see the load instead of building a box around it. This is really critical if the load is off center. I would not hire the construction of shipping crates. Most of the work I see come in seems to reward excessive nail gun useage. They must charge by the nail!!! All those work loose on the interstate. Dry wall screws snap off under load. Use good quality wood screws. Signs mean nothing on the crate. If you don't want anything stacked on your crate, build a pointed or angled top on it. If another load can't physically sit on your crate, that's your best option. Insure to the max, and take lots of photos, before shipping and upon arrival. Don't let a trucker leave until a fair inspection has been preformed. Make the trucker sign everything with times and dates.
>I recently shipped a Porter-Cable radial arm saw to someone - California to Ohio. The shipping company insisted on a crate, even after I put the saw on a pallet. I used 1/2" OSB, which turned out to be insufficient armor against a forklift operator, who miraculously managed to miss the saw when s/he put two fork-shaped holes through the OSB.
I bolted the saw down AND ran rope across it in two directions, using trucker's hitches to get it good and tight. I also taped and roped every part that could vibrate, and supported the end of the arm on some styrofoam, using heavy zip-ties to push the arm down firmly on the styrofoam.
I used 2x2 Doug fir (offcuts from a building project) as inside corner posts or cleats and screwed the OSB to them, so each corner was held together from two directions.
Were I doing it again, I would use 3/4" ply, and better screws (I had drywall screws, so used them for the most part, with a few high-grade drive screws for critical parts; but I know how fragile drywall screws are).
>There are two major methods of shipping small quantities of large objects - small being less than will fill a long Class I trailer:
1. "Blanket wrap," which is the kind of packing mostly used when you move house from one place to another. It's just what it sounds like: the movers wrap each object as lovingly as their mood that day permits in moving blankies, pack the truck so that items aren't stacked atop each other (at least in theory), and reverse the process at the destination. Likely expensive, because of the amount of air being transported in the trailer and the extra labor involved.
2. "Less than truck load," in which your item is one of the thousands of items trucked around the country. It will be put into a fully loaded trailer, and may be moved from one trailer to another in order to reach its destination (kind of like human air travel, but without the dry, tasteless peanuts). Probably cheaper, because the items can be moved around the shipping company more efficiently and more of the trailer is filled with objects being shipped.
I learned, when I shipped the radial arm saw mentioned in another post, that there are multiple players in the mix: the company with which you arrange your shipment may be a broker who contracts with one or more other firms to do the actual shipping. The buyer of my saw worked with a broker local to him, who said, "All it needs is to be put on a pallet." The first (of three) times I arrived at the actual shipper's depot, the saw was refused, because they wouldn't ship without a crate around the saw. So ask lots of questions, and don't start packing/crating/preparing until you've talked with someone at the depot at which you'll drop off the tools and confirmed their requirements.
>Thanks for all the replies! One thing I should probably mention is that we're thinking of buying a shipping container, packing it full with the shop equipment (and anything else in the house that will fit) and having it moved to our property so we can sort through it at our leisure. In this scenario, we would have a bit more control over how the container was packed, and forklift damage isn't as much of an issue. (Though we may want to rent a pallet jack to move stuff around)
