Drawer Rocks
Drawer Rocks
Doug in Seattle
Drawer Rocks
Doug in Seattle
>When making drawers with through and half-blind dovetails, I sometimes find the drawer rocks from diagonal corners. What is the best way to correct this while gluing up?
Re: Drawer Rocks
Re: Drawer Rocks
>This is why you have to mill the drawer parts extremely accurately. If the pieces are out of square the error will be multiplied by the length and width of the drawer.
If you glue up the drawer and set it on a flat surface while the glue is wet, you may be able to force it to the surface if the drawer is "winded" of twisted. If the joints are tight and strong then the drawer may just spring back when you take is loose. If there is a little slack in the joints And you are dealing with very small increments you may be able to leave the error in the joints.
And you can hand plane the drawer into submission if it is not too bad.
Re: Drawer Rocks
Re: Drawer Rocks
Robert Lemon, Sacramento  CA
>Doug, Barry is right about measuring your sides very accurately, but you can also be creating problems with your depth of cut on the dovetails. On your next drawer, dry fit and clamp to thoroughly seat the dovetails, then check to make sure the joints are square vertically.
ShopNotes Issue 36, page 6, has a frame clamping jig that works very well to keep items square. We made a couple of different sized bases and doubled up on the corner clamps to use for boxes. Worked great. If you would like pictures of it, let me know.
Bob
Re: Drawer Rocks
Re: Drawer Rocks
Keith Newton----Little Rock, Arkansas
>Are you sure that your wood was flat to begin with. If there was a slight twist in the lumber, then it gets multiplied even if you get everything else square.
Re: Drawer Rocks
Solve the fundamental problem
Bill Tindall
>Presuming the lumber is perfectly flat, drawers rock because of some error in the preparation of the dovetails. You did not say how you were cutting the dovetails. The likely source of the error depends on how the dovetails were prepared. If they are machine cut then the source of the error is 1. The ends of the stock are not perfectly square and/or 2. the pieces are not held in the jig perfectly square. Let me emphasize "perfect".
If these are hand cut then the error is either 1 from above or 2. the pieces were not perfectly aligned in the same plane when the pins were marked from the tails. I have a nice trick for ensuring the pieces are in the same plane when marking. I never could do it reliably as shown in the DVD demos.
A properly prepared dovetail drawer can be assembled without clamps and the drawer will lay flat and be square. There is no fixing a rocking drawer problem during glue up unless the joints are too loose.
Re: Drawer Rocks
Bill, what's your trick?
Al Goldstein
Re: Drawer Rocks
Doug in Seattle
Re: Drawer Rocks
Doug in Seattle
>Drawer stock was dry and flat when I started. This is Seattle however. Drawer sides and backs were squared on a shooting board and all dovetails were cut by hand (dovetail saw and chisel). It only rocks maybe a 1/16 of an inch. If I truly fit the drawer front to the opening, however, it may not be square to begin with. I would assume this compounds the issue.
Thanks for your comments. I have more to make and will keep an eye on the stock.
Re: Drawer Rocks
This perhaps?
charlie belden
Re: Drawer Rocks
fool proof marking
Bill Tindall
You will need some sort of right angled piece, a flat surface and two clamps as shown in the picture.
I have used a section of plastic angle iron, a single right angled dovetailed joint or a cast iron right angle block from a machine shop supply place such as Enco.
While this arrangement takes slightly longer than holding by hand on the bench, it ensures the two pieces will be planer when the joint is marked. Added bonus is that you can pick up the assembly and orient it for optimum marking. And it is so precise in alignment that if you forget to mark one pin you can reassemble and get perfect realignment (not that I ever forgot to mark a pin.........well maybe once).
Re: Drawer Rocks
PS
Bill Tindall
>The blocks under the clamps will squeeze any cup out of the thin sides, should there be any.
Re: Drawer Rocks
Thanks
Al Goldstein
