Old router
Jay
>I recently attached my P-C Model 690 router to the router table I build. In order not to have to dismantle it each time I need a router, I just picked up a P-C (US made) 100-M Motor (115 V; 6.5 amps). It was a very good deal so could not resist. I have now dismantled it and the copper wire connecting 1 of the 2 carbon guides (bushings?) is disconnected so I will re-solder it (the spring is OK), however the guides/bushings appear quite worn. Is this dangerous? Can I find replacements easily? Also am I cruising towards a potentially unpleasant/dangerous situation if I don't replace them? Everything else appears in good order (collet is tight, etc.).
Would appreciate some knowlegde from anyone that knows routers from the guts up.
Thanks, Jay
