Ivory
Ivory
Ivory
Ken Oakley-Sunny St. Cloud, Fla
>My wife a two pairs of purse handles that she thinks are Ivory- I tend to think they are plastic, yet can not find any mold parting lines. How can I tell if they are Ivory. Also I know there is a ban on the sale of Ivory, but there are exceptions to the rule. Anybody know?
Re: Ivory
Re: Ivory test (from the net)
Gary Smyth
>The tried and true method to test ivory is the famous "hot pin test". This method is used by beginners and experts alike. Because true ivory is virtually impenetrable with heat, this is a good test and will not damage the item if it is "real". Take a pin, large needle, or better yet a large straightened out
safety pin, and heat the tip RED-HOT. Poke the item somewhere that it will not show too bad. If it is real ivory, it will NOT penetrate and only leave a tiny tiny mark. If it is a resin, it will enter the item and produce a little crater around the hole. Now the big test� smell the "smoke" that comes of the test as you are poking it. If it is real ivory, it will have that unmistakable smell of the dentist's office when you had that root canal (stomach turning). It smells like burning tooth (because it IS). If it smells like burning plastic, it IS. Now, bone is also resistant to heat, but not as much as ivory. The smell is less (or hardly at all) and is different than that of burning tooth.
Most bone carvings are "capped" on the top and bottom as all bones are hollow. If an item is carved thinly enough to be carved from the wall of the bone (usually not thicker than 3/4") it may appear to be ivory. But, bone is absolutely free of grain and will ALWAYS have little "pock marks" (sometimes brown and sometimes not) in it where the marrow or blood was. You may have to use a loupe to see these pock marks. So in conclusion, if it resists heat, smells like crap, and has any grain (especially crosshatching), you have the real deal.
As to the ban you can find all you want on the web. Ebay stopped Ivory last year. I believe that there is a age that ivory must be to be traded. Old chess sets for example.
