THE WOODRAT IS BACK!
OT Cleaning Pizza stone
>Anybody know how to clean a pizza stone? I don't have a self cleaning oven. I have heard you can run them through the clean cycle on a self cleaning oven, but that is not an option for me. Is there another way that won't ruin the stone? I was considering putting it n the oven at 500 degrees and then burning the stuff off with a torch, but I don't know about that either. Oven cleaner might work, but I don't want to eat off something that has oven cleaner on it.
Re: OT Cleaning Pizza stone
FredD
>Try putting it in the oven with a oven cleaner Bomb and kill two birds......
FredD
Stuart Johnson
>Stick it in the 500 degree oven for an hour then scrape any hard bits off with a spatula. Brush the stuff off and don't worry about any discoloring just call it patina.
Jennifer@Indy.USA
>I've had one for over a year now and we use it probably 2-3 times a month. We just scrape anything off and then wash it in the sink. They do get to looking grungy but that's normal. Ours is almost all black and burned looking but it makes the best pizzas!
Jen :b
Tom Pilsbury (Chicago)
>Instead of a regulation pizza stone I use unglazed quarry tiles. Four tiles butted together is just the right size for a 12" pizza. Much cheaper than a stone and if one breaks or gets too grungy throw it away and replace it with a new one.
Same here, but...
Bill Earl
>I only toss them when they break. Just scrape off any loose crusty stuff and don't worry if they start to turn black. A nice dark patina helps to brown the crust better.
Gary Camp, Bend Oregon
>My wife has managed a couple of food service facilities that did pizza, and one of the kitchens I maintain has a large double pizza oven. The only cleaning the cooking surface in these ovens get is scraping, wire brushing and a shop vac. As others have noted, srcape it, and wipe it. It is just getting "seasoned"
glc
Why?
Bill Tindall
>I use unglazed "quarry tile" and line a shelf with the tiles. But I have seen no need to clean them ever. They get preheated for nearly an hour at 550F so anything on there gets turned into carbon. I suppose you could burn off the carbon in a hot charcoal grill.
OK Then grungy it is....
>I have been making little home made pizza's using a tortilla or a wrap for a crust and whatever I want on it for toppings. A smear of marinara and some healthy stuff. The stone works great. 8 minutes at 500 degrees and you got yourself a nice little pizza for one. Somehow I just thought I should clean the black spot off the middle of the stone. If it ain't broken don't fix it.
Pampered Chef . . .
steve mackay
>I don't think you mentioned how bad it was but I soak my Pampered Chef stones then green-pad them. They are porous so they do dis-color over time but as long as there isn't any build-up on them they work fine.
Re: Pampered Chef . . .
>My cheap Walmart stone is more than discolored. But only slightly. It has a film of blackened grunge. Next time I use it I might leave it in the oven after the pizza comes out and turn the oven all the way up. I guess I could broil the heck out of it.
Re: OK Then grungy it is....
Carol Reed
>Corn or flour tortilla? Brand of sauce? Brand of wraps? I have a stone still in the box and I love pizza. I gotta try this! Stone is still in the box after 5 years because I am not really a cook, but I can be motivated!
8 minutes at 500 degrees? WOW! That's hot. Does the stone need to be preheated? Oven or broiler?
Agree
Dan Donaldson
>Need a recipe
Pizza recipe.
>First Make a pizza peel. :)
Preheat the oven with the stone in it on an upper rack to 450 degrees (F).
I am using Tumaro's Gourmet Tortillas that are 10" in diameter. They come plain or with various flavorings (chipotle chile peppers is my current batch, but I don't think the flavor adds much) I have also used other flat breads.
Three serving spoonfuls of Ragu marinara. This is a thin smear. Think primer coat. Don't make it heavy. Spread it right to the edges to help reduce the burning of the edge.
Sprinkle on Italian seasoning or oregano and basil, a good sprinkle, maybe a teaspoon. And a good grind of black pepper.
Add toppings. I am using very thinly sliced sweet (Vidalia) onion, canned sliced mushrooms, black olives, green olives, and whatever. Then I cover it with mozzarella Cheese and put turkey pepperonis on top of that.
I assemble it on my peel I made for the purpose and slide it onto the stone. About 8 minutes or until the cheese starts to brown.
Then its out, onto a cutting board, slice it and eat it. Makes a thin crust personal pizza. The tortillas and flat bread come in many sizes and shapes so you can make as much or little as you want. I buy pacakges that have six in them and they seem to keep forever in the fridge.
I get the toppings at the local grocery store that has a prepared food center and salad bar. I just go down the bar and load one of their containers with anything that looks like it would be good on a pizza. Several kinds of cheese, olives, pepperonis, whatever. I tried sunflower seeds and pumpkin seeds. Maybe not next time. I find it interesting that the stuff I put on a salad is pretty similar. I often buy extra and a bag of salad and that makes dinner for another night or two.
Thanks, gonna have to try that.
Dan Donaldson
Re: Pizza recipe.
Carol Reed
>Thanks, Barry.
So, make a pizza peel. It's even woodworking related!
How do you make a pizza peel?
Jason Roehl in Lafayette, IN
Interesting.
>Our baking stones (we have a pizza round and a low-edge pan) are only discolored at the edges, and they're not black, more like a dark caramel color. On the pizza round, it's only the outer inch or inch-and-a-half. The rest is more or less the original color, and it's seen a LOT of use over several years. If I think about it this afternoon, I'll post up a pic.
Jason
That's not pizza!
Bill Tindall
> Might as well order out Domino's . Now if you want real NY or Italian pizza and don't have some local Italians to buy it from, buy Reinhart's (author of bread baker's apprentice) book "American Pie, my search for the perfect pizza. Note: in the winter with the house cooler it may take a long time to get the dough raised perfectly. If the dough comes out too dense and there aren't huge bubbles around the edge, let the dough rise more next time.
The thermodynamics of pizza cooking is as follows. The heat stored in the stone must be sufficient to cook the crust. The heat from the oven melts and glazes the cheese. These two processes must finish at the same time.
The typical home oven can not achieve ideal pizza cooking temperature (600-1000 degrees for commercial ovens), so set the oven to Max, 550 in my case, and let the tile heat for about 1 hour. If the cheese needs a bit more heat to come out right then a boost from the broiler will work.
PS I prepare the pizza on a cookie sheet with a sheet of parchment paper under it. With this arrangemetn I have no problems sliding it off onto the hot rocks.
Re: Interesting.
>My son has used the stone more than I have. (Boomerang kid) I have no idea what he has cooked on the stone. Knowing him he may have tried cooking the pizza face down and turning over onto the plate.
I am not concerned about germs. Pretty sure any germs that might have been there are totally roasted by now. I was just wondering if the thin layer was having any effect on the cooking.
Pizza Peel.... or Peal
>A year or two ago I realized my son was cooking lots of home bake pizzas. I made him a peel. Three scrapes glued together to about 12" width. (I have a lunch box planer, so that was about the limit.)
Made a tapering jig by sticking shim shingles to the bottom of another scrap with double stick tape. Stuck the peel blank to the taper jig with double stick tape and ran it through the planer handle first. Jig has to be "tall" enough to allow the handle to hang down. Once the lead end was about half thickness, I turned it over on the jig and planed the other side till the lead end was about an 1/8". I think I double the wedge thickness at that point. A drum sander like a Performax would do this and might be less scary, but it worked fine with a planer. Rounded the lead end, cut the handle to shape, Sanded to 400.
You could bandsaw the taper if you had a bandsaw. You could just taper it on one side, but how fun would that be?
Really, Sanded to 400? My son was so happy with it he immediately cooked a pizza and cut it up with a pizza wheel right on the peel. I was stunned and horrified. Now he puts it on a cutting board.
If you have a wide enough scrap you would not have to glue it up. OTOH, Mine has cracked along the glue joints. I posted it as a possible Christmas project and someone commented that the ones they had made had also cracked whether they were glued up or not. I like mine, cracks and all, but if I were doing it again, I might leave the lead edge a little thicker and sand or plane a secondary bevel on it. Mine is Cherry and sycamore. I'm deciding slowly whether to run the saw through the joints and glue them or just let it go and make another. Might us this one as a pattern/jig for the next one.
Make two or three. Like most of these things its all in the set up. The actual project used less wood than the jig. So two would be about 10% more trouble than one. Everybody that has a pizza stone wants one once they see yours.
Now that's a PIZZA
>Looks fabulous. I have been playing with pizza for years. Every once in a while. Cooked some on the grill a few yeas ago, right on the grill, without a stone.
The ones I am making now are not gourmet classic pizza. The flat bread or tortillas provide and instant thin and crispy crust and serve as a vehicle to get the toppings into your mouth without adding a lot of calories or carbs. I am pretending these are healthy or at least healthier. (Please don't tell me is they are not.) I use low fat cheese, turkey pepperoni, and lots of veggies. Works well for a quick meal. I can put the pizza together while the oven is preheating and then cook it in 8 minutes or less. I may start backing off on the cheese.
Yours looks better and makes me hungry.
Re: Interesting.
Ron Bauman
>I've got a peel and a stone, I use a sprinkle of corn meal on the stone just before putting on the pizza and when done it slides right out. Can't remember who told me to do that.
Re: Interesting.
>I had forgotten about the corn meal. We have done that. Maybe that is part of the grunge.
Re: Interesting.
>Normally in a commercial oven the cornmeal just browns a bit and and you sweep or shop vac it out periodically. It doesn't really stick to the stone or brick and contribute to the "grunge"
glc
