We value your privacy.
>This is the foot stool that goes with my 20 year old Eames knockoff. The veneer is glued to a plywood substrate. It has chipped off and at the chip locations is pulling away from the plywood.
>I would start by sanding all of the veneer down to bare clean substrate, then vacuum-bag new veneer on the whole underside.
The cushion is probably held in place with snaps.
I like epoxy for this kind of veneering.
You may need an extra pair of hands to hold the veneer down while the air is being evacuated, otherwise the bag gets drawn into the edge of the glue-line.
With epoxy, you have plenty of time to get it right, and squirming around doesn't hurt it even if it has already started to jell, so long as everything is in contact for the rest of the cure.
ONce the vac is drawn, you can speed up the cure by setting it near a heat source to warm up.
You can read enough above to figure out how to get started on the cheap. After this project you will be on your way to much greater things.
