ADVERTISE HERE - FREE TRIAL
Attaching A "Return"
Paul Regan
>Hello All-
I am working on an "L" shaped desk for a home office. One leg of the L will attach to the other. The main desk will have four legs and the return will have two at one end and attach to the main desk at the other (so that the return legs will not interfere with the desk chair as one slides from work area to work area along the desk). It will be a very long work surface when complete. I was hoping for advice to attach the return in such a way as to be invisible on the main desk when removed. I am trying to avoid obvious joinery, but still have a work surface that is properly supported and feels solid.
Any advice and/or hardware you can recommend would be appreciated. Oh and by the way, Happy Truck Day, New Englanders.
Re: Attaching A "Return"
Lee Schierer McKean, PA
>We have desks like that in our office, they used threaded inserts in the bottom surface and a metal plate to joint the two pieces. Nothing is visible from the top.
Paul Regan
>Thanks for your reply. I�ll check the hardware catalogues for fasteners. Just curious, do the desks have aprons, or is the spot where the two surfaces meet level and even on the bottom?
Thanks
Bill Houghton
>If yours is an apronless design, I would go to a metals scrapyard and buy a piece of thickish - 1/8" steel or 1/4" aluminum - stock wide enough to cover at least half the width of the "L" leg and long enough to allow one set of screws into the "L" and two sets, 6" or more apart, into the main desk. This is probably overkill, but if someone leans on the "L," s/he could pull out one row of screws, causing damage and much embarrassment.
Aluminum would be easier to drill, but might be more expensive. File any sharp edges off.
>They are even on the bottom, but there is a privacy screen on the "front side of the desk and extension. The metal plate is about 1/8" thick and is set back from the edge where you sit by about an inch. I've attached a photo if that helps.
Lee
