OT: Preventing Ice dams on roof gutters
Dominic in Buck's County PA
>With all the snow that fell over the last couple days and the freeze/melt cycle going on my house has developed a problem with ice dams occurring along the roof gutters. The melt water is running down the side of my house and causing water to leak into the sill of my sliding glass door.
Now I know there is more than one issue here. The sliding glass door was installed by the idiotic former owner. I believe that he neglected to use the proper molding for the upper sill and probably never installed flashing. I swear that guy could screw up a two sandwich picnic. I've had to fix more of his home handyman repair time bombs than I'd care to mention. Needless to say as soon as the weather breaks this is going to be my next project.
I looked on the Internet and found this article: What is an ice dam? . In reading it I found the following information:
Dealing with ice dams
Immediate action:
Remove snow from the roof. This eliminates one of the ingredients necessary for the formation of an ice dam. A "roof rake" and push broom can be used to remove snow, but may damage the roofing materials.
In an emergency situation where water is flowing into the house structure, making channels through the ice dam allows the water behind the dam to drain off the roof. Hosing with tap water on a warm day will do this job. Work upward from the lower edge of the dam. The channel will become ineffective within days and is only a temporary solution to ice dam damage.
Long-term action:
First, make the ceiling air tight so no warm, moist air can flow from the house into the attic space.
After sealing air leakage paths between the house and attic space, consider increasing the ceiling/roof insulation to cut down on heat loss by conduction
I need to know what ELSE to do in order to prevent these ice dams from forming. I'd rather NOT run some kind of heat trace up there since any kind of electrical solution would be problematic. The attic below this room is insulated with that shredded paper that was so popular in the 80s. Would replacing this with fiberglass be an improvement? Also would those "gutter guards" help?
Thanks,
Dominic
