How high should the saw blade be?
Bill Tindall
>Last night our club had a program on saw blades given by a person from Freud (who would be delighted to give your club a program).
In addition to providing informative information on how the blades are designed and manufactured there was advice on selection and use.
The tooth angles of Freud blades are designed to be used with half the length of the carbide teeth projecting above the cut.
The blades are designed to be used this way because Freud believes this is the safest way to use a blade-"laceration, not amputation". I agree wholeheartedly. Because Freud blades have adequate side clearance of the teeth they can be used in this configuration without excessive pitch build up.
We were told that the main wear factor is heat which results from dirty blades.
