Re: Tablesaw Surface Question
John in NM
>With no coating of surface rust, I can guarantee there's no on-going pitting occurring. I don't think you have much to worry about in the Arizona climate - Florida might be another story. I have an old jointer that has moderately severe pitting on one end of the infeed table. It looks to have been stored outside and ineffectively tarped, and must have been rained on for years. As long as there is not active rusting going on, this is really just a matter of cosmetics. Wax it and forget about it.
You could try adding a little solvent to your wax, that might help get a thin, even coat to be buffed out. I only use wax to reduce friction on the top, its not much of a protective film IMHO, and cast iron doesn't need a whole lot of protection. Wax will help prevent the nuisance oxidation, but will quickly wear off under normal use. If you get a little surface rust during the monsoon season or an abnormally wet winter like the current one, just buff it off with some steel wool and re-wax.
