V-Drum sander
V-Drum sander
V-Drum sander
BrianA
>Was wondering if anyone has built an under table sander like the Flatmaster or Sand flee. Saw the Flatmaster at the wood working show in Milwaukee. Looks pretty cool and the kit you can buy from them looks a bit steep. I was thinking a 4" PVC pipe filled with something to remove any flex as the drum. But.. was wondering if anyone has done this yet?
Brian
Re: V-Drum sander
Re: V-Drum sander
>I made a table to go on my Performax to turn it into a Sand Flea type sander. Does that count? I really like it for some things.
Re: V-Drum sander
Re: V-Drum sander
BrianA
>Ahhh...no. But nice try;-).
Tough going to the wood working show and laying in bed trying to figure out how I can build it on my own for cheap. In my head I'm thinking PVC stuffed with wooden disks to hold it's shape with a shaft running thru, motor and table and Voila!!
But thanks for the thought.
Brian
Re: V-Drum sander
Re: V-Drum sander
Norm-Knoxville
>Brian, my son and I bought a Flatmaster at the Nashville show a couple of years ago. Wish I had the money for a drum sander, but all things considered this was not a bad purchase. I am still using the same rolls of paper I bought at the show because it does not fill up. It does wear out, but there is plenty on the roll. I mostly use the unit for door panels / frames and picture frame stock. It does what you saw at the show. Pretty handy at times.
Re: V-Drum sander
Re: V-Drum sander
BrianA
>Is the drum made of aluminum? Do you think I could make it out of PVC?
Thanks
Re: V-Drum sander
Rick L
Re: Reinventing the wheel...
Rick L
>Skip the PVC and just use the plywood discs. Instrument makers have been making drum sanders this way since the 60's that I know of. The flatsander is just a simpler form of this. Personally I don't see the point of a flatsander but I've used and worked on everykind of sander you can imagine.
Re: V-Drum sander
Re: V-Drum sander *LINK*
Dick Coers
>Here is a link to a build using PVC. The guy says it works great. I do think he machines the pvc on a metal lathe, but I think he says it was barely out of round. If you've seen the demo, you know the wood doesn't touch the drum. I will be making one for myself soon. I have started making wood jewelry and finding a way to sand the small parts without wearing off the skin on my fingers makes this machine look like a good deal. I especially like the idea of using 3 different grits across the drum. That will work great for me.
PVC sanding drum build
Re: V-Drum sander
Re: V-Drum sander
BrianA
>Dick,
Thanks for the link. Lot of the same ideas running thru my head.
Brian
