We value your privacy.
>Most of the ripping I encounter does not require precise width setting. It hardly matters if the frame on a frame an panel door is 2, or 2 +/-1/32, a tolerance I can easily set with a pointer marker on a fence (current project). If I screw up a piece and need to make another later I use a piece I have already cut to precisely set the fence postion. In fact any precision setting I can remember could rely on empirically setting the fence to the width of some piece I had at hand. In what circumstance would a digital read out be more useful than the pointer, standard on a fence?
It is generally the case that nearly all precise measurements in constructing furniture can be obtained empirically. Need something to fit exactly. Well, hold up the piece to be cut to the opening and scribe where the cut needs to be. The more I think of this option the less I have had occasion to reach for a ruler, and the better the fit.
>I have their planer Digital Scale. I'm not thrilled with it. The biggest issue is that it eats batteries. The other issue is resolution. I'm not going to get in to the argument of how close does it need to be, but the resolution seems a bit coarse for how I work. Not sure about the TS model though. The folks at Wixley were real nice to work though. I thought about upgrading (they offer a deal). They said that the new model doesn't use as much battery power as the old one.
So many factors determine the width of a rip that I suspect this is just a gadget to get your money. The fence and blade on a table saw can easily move or flex several thousandths of an inch during a cut, and no joint in wood ever has to be made to such tolerances. If you don't trust your fence gauge, use a steel reference rule to set the distance from tooth edge to fence. A digital read out will not make your saw cut better or your joints meet better.
Remember too, if your fence won't keep precise settings, this widget will need to be constantly reset, zeroed, adjusted, and finally put in its box in the "I-bought-it-but-don't-use-it" tool drawer.
>I have the Wixey on my 15" planer and have great results. I can go back to my planer at any time and mill a board to the thickness I want +/- .005. Yes I do understand that we are working with wood and don't need that close of tolerance, but sure is nice not having to keep measuring the board as you mill. I will add the Wixey to my tablesaw in the near future.
>I use it to calibrate my table saw on occasion. I also use it to adjust my jointer fence on the rare occasions when I actually need an angle.
I don't think a digital read out would be that beneficial. I've got a reasonable measure on my fence. It is reasonably accurate and reproducible. If I need better measurement, I've got a nice ruler that I can use.
>Great concept, poor resolution. 0.005" might seem too close to some people but when you consider that a good glue fit in woodworking is 0.002" to 0.005" loose a DRO with 0.005" resoluton doesn't quite make it. If it had 0.001" reolution and reasnable accuray over that range (say 0.005/ft), I'd buy three.
Explaining: I'm a machnist. Over 50 years in the trade I've learned to work in 0.001" increments. I convert fractions to decimals in my head because I have the chart memorized to 1/32". So close accuracy holds no fear or loathing for me. I submit accurate work on the stock prep and joint machining means little or no fitting and adjutment later come time for assembly. I use a 1" travel dial indicator on a magnetic (hockey puck) base to make fine adjustments to my rip fence. I keep it near the saw just for that reason. I've also worked to story poles and other non-measurment techniques but when I have to fit and measure I'd rather work to decimal fractions. Real woodworkers might say they work to fractions but they fit to thousandths whether they realize it or not.
My experience shows that Wixey products are battery eaters. I have their very handy little block protractor. I have to change batteries every few days if I use it regularly. If it's used once a month I better have a fresh battery on hand because the one I left in it is sure to be dead. I have a couple Mitutoyo Digimatic calipers and the batteries in them last for a couple of years whether I leave them on or off. From this I conclude good battery life is implicit in the technology.
So, Wixey, your challenge is to increase the resolution to 0.001", travel accuracy to 0.005" per ft, and to improve battery life to 500 hours at least. Do that and I will buy three of your rip fence DRO's.
>I am not a machinist. I can understand wanting 0.001" accuracy in machine work. Heavens, when I worked in the packaging industry we were specifying film gauges at 0.1 mil for some of the multilayer structures.
But we are talking wood here, right? I mean if the humidity changes 20-30%, you might get 1/8" change in the width. I try for 1/64" (0.015") accuracy in some of my work. I am happy if I get 1/32" .
I do agree with you 100% on the battery life. To me, If you turn something OFF - it shouldn't still consume batteries. I typically remove the battery from my "cube" when not in use. I learned my lesson the hard way. I left the battery in for a couple of months and when I tried to use it again - no battery charge.
>I agree that most of the time we don't need accuracy to a couple of thousandths. Mostly what we look for is that two pieces have to be the same size or one needs to be proud of the other so that it is pleasing to the eye. Our sense of touch is extremely delicate and putting two pieces on a flat surface and running your finger over them is an excellent way to compare. Scribing can be accurate if you are careful.
Some joints, e.g. mortise and tenon, do benefit from a consistently precise fit. Too often when we are 'tuning' a fit, we wind up with a great fit at the fattest part of the tenon and a mediocre fit elsewhere. If the piece isn't going to take a lot of stress or last a long time, you can get away with that.
There are also times when we derive a number mathematically and need to translate it precisely to wood. When I make chairs, I use a lot of compound angles. I use a formula to calculate the resulting 'real' angle from the compounding and then use a Wixey angle guide to set my miter. Way faster than drawing full scale pictures or finding the angle thru trial and error.
One last comment in this wordy reply. Don't trust those digital gadgets! Just because it shows a measurement accurate to 3 or 4 decimal places, doesn't mean its correct. The first angle guide I bought produced different results each time I placed it on the saw blade, even if I didn't move the blade. But all the results showed hundredths of a degree....
>JT Not to belabor the point but if you fitted a panel to a stile, a shelf to a dado, or a tenon to a mortice with 1/32" interferance or clearance you would not be happy. I agree that wood is constantly moving but in rough proportion to the dimension reckoned. Don't believe me? Get out whatever precision tools you have and check a few of your better joints.
I'm quite sure that any piece of cabinetwork, shop aid, shelf unit will work fine if made to +/- 1/16" overall tolerances or coarser if it stands alone. The point I'm stressing it how well the joints fit. As I said in my previous post, you may not be aware of it but if you are doing skilled woodwork, you are working to thousandths; you simply aren't measuring them. A few thousandths one way or another is the difference between a closed joint that is too tight or too loose.
Hell, I know framing carpenters who will glare around for a gulty party if a pre-cut jack stud has to be hammered in or it falls out before he can get a nail in it.
>I purchased a Wixey Saw Fence Digital readout. It was simple to install on my Sears (Orion) table saw with a Biesemeyer fence. I was able to avoid any drilling.
I do not use this as much as I expected due to the "rounding" effect.
The scale use to read position is not as accurate as I require. This is based on comparing the digital readout to the actual scale tape.
This may seem trivial, but when trying to make repeated cuts, I find the digital "rounding" error can equate to being 1/32 off. For some cuts, this is a problem for me.
I still have the unit installed on my fence, but I do not use this as often as I anticipated.
>>...Wixey products are battery eaters. I have their very handy little block protractor
This prompted me to to check my little Wixey angle block. I only used it once to test it when right after I bought it a couple of years ago. The battery was deader than dead. This is nothing but technical incompetence.
I have a quality Mitoyo digital caliper that has had the same battery for almost 20 years now, and that is with occasional use. Good grief, that's the last Wixey product for me.
