OT: Algebra Question? Factoring
Basil
>Factor this equation for me...I have an answer but my son disagrees with me.
(X3-100)....that's X cubed minus 100
I used the formula (a-b)(a2+ab+b2).... That's (a minus b) times (a squared + ab +b squared)
....and that, at least in my view, is
(X - cuberoot of 100) times [X squared +(cuberoot of 100)X +(cuberoot of 100)squared)]
Hey, it has been 45+ years ago that I learned this stuff. I can't find an example with an imperfect cube anywhere in his algebra book. This is a "special" problem his teacher gave then for homework.
My son thanks you in advance...you may have saved his life...and kept me outta jail...LOL
Re: OT: Algebra Question? Factoring
Alexander Grigoriev
>To test that, do the reverse calculation. You'll then get the original expression.
I did.
Basil
>He still doesn't believe me...what can I say. He took after his hard headed daddy....LOL
But  *LINK*
>That's not an equation, it's an expression. Is something missing? If you infer a value of "0" then, by simplification and reordering you can solve "a" as the cube root of 100, but I don't think that's what your asking, is it?
As it's been more than 45 years since I nearly failed algebra, I cheated and went to an on-line helper. Enter the expression (with a ^ to set the 3 as a power) and click "factor" and you get this:
Simplifying
a3 + -100
Reorder the terms:
-100 + a3
Final result:
-100 + a3
That seems to say that you can't "factor" the expression because you cannot pull out a common distributive GCF
see the link
Factor Dis
charlie belden
>An Equation requires an Equal Sign (=).
X^3 - 100 is not an equation
if you're looking for the number "X", which
when multiplied by itself three times is equal
to 100
then the Equation would be
x^3 - 100 = 0
To get the unknown X that you want
you need to get IT on one side of the
equal sign - and everything else on the
other side of the equal sign.
Now the rule is
If you do the same thing to everything on
BOTH sides of the Equal Sign you maintain
the balancing act
So
ADD 100 to both sides of the Equal Sign
X^3 - 100 + 100 = 0 + 100
do the simple math and get
X^3 - 0 = +100
or
X^3 + 0 = +100
or simply
X^3 = 100
Again doing the same things on both sides
of the equal sign again
take each side to the one third power
(take the cube root of each side of the
equal sign)
and you get
X = 100 ^1/3
(X = the cube root of 100)
works out to
X = 4.6515883 according to Excel
If you've got a calculator you can
check that by multiplying that value
You are correct. *LINK*
Dan Donaldson
>Here is some further support ;)
Factor difference between two cubes
Re: I did.
K. Goring
>Your answer looks correct to me (I made it thru engineering school... lots of tricksy problems like this...). It solves when you multiply it back out.
Unique?
Wiley Horne--So. Calif.
>You're factoring an expression. There could be many factorings. For example:
(X3/2 + 10) (X3/2 - 10)
where X3/2 is "X to the three halves".
Wiley
Thanks fellows.
Basil
>OK ...I used the wrong word. I should have said "factor this expression." X3-100
I think I have a solution and Wiley also came up with one that works.
Sons algebra teacher says, "It has no solution." I guess she means it can't be solved with a nice whole number cube/root or whole number exponents.
Still not sure if I'm smarter that a fifth grader.
Re: Thanks fellows.
Dan Donaldson
>"It has no solution" usually just means "we have not taught you how yet" ;)
Re: Thanks fellows.
Alan in Little Washington (NC)
>Both Wiley's factoring and yours are correct.
Algebraically you can easily factor the difference of two cubes as you have shown, however 100 is not a perfect cube. If we set 10 equal to b, then 102 = b2 or 100 = b2 then the original expression you are attempting to factor becomes a3 - b2 and different that what you factored.
To check your factoring expand the terms by multiplying using the distributive property:
(a-b)(a2+ab+b2) = a (a2 + ab + b2) - b(a2 + ab + b2)
using the distribution property again gives you: a3 +a2b + ab2 - a2b -ab2 -b3
grouping like terms you get: a3 + a2b - a2b + ab2 - ab2 -b3
and simplifying you are left with a3 - b3 which is not the expression you are looking for.
Since 100 is not a perfect cube the original expression can not be factored without using fractional exponents. The easiest way is to manipulate the terms and treat the expression as the difference of two squares as Wiley has done or the difference of two cubes as you have done.
Base 10?
>Did the teacher say the numbers were in base 10? It would be simpler in octal. (cube root of 100 in base 8 is an integer)
Re: Base 10?
Dan Donaldson
>Now that would be a trip. Have a 5th grader take this problem to school and tell the teacher:" See, if we assume that this problem is in octal, then it is simply the difference between two cubes and factors as follows...." Would I ever love to be the fly on the wall in that exchange ;)
As a retired math teacher
Rich Pearson in Mill Creek, WA
>I am very impressed with the clear explanations given here!
Great work on the difference of two squares or two cubes and that BOTH are correct factorizations.
I especially appreciated Alan, JKJ, and Dan's contributions. The clarity and creativity in the explanations (I LOVED the octal approach) may just inspire yet another young student to go farther, fly higher, etc.
This Forum has got the real deal!
Re: As a retired math teacher
>Thanks, Rich.
I'm sort of a retired math teacher. I got my teaching certificate and M.Ed. while on active duty, but after retiring from the Navy I taught HS math for awhile. As the newby, but with military experience (whatever that is worth), I was given the less advanced and (much) less motivated students. It was more stressful than landing aboard a carrier on a dark, nasty night! I only lasted three years until the stress and a heart attack convinced me I was not meant to be a teacher. I returned as a civilian to the much less stressful Pentagon rat race! I have great respect for woefully underpaid teachers.
FYI- I spent quite a few years up your way flying the EA-6B Prowler at NAS Whidbey, Is.
