ADVERTISE HERE - FREE TRIAL
Stain drying issue - help?
Stephen Kirk
>I put a coat of minwax pecan stain on my oak table top last night, let it sit for about 10 mins, then thoroughly wiped it all off. I even left my shop heat on for a few more hours to help it dry. When I saw it this morning - after a night in the cold shop - I saw a number of places where it looks like the stain seeped up from the wood, leaving little drops on the surface that didn't dry. They are a bit sticky now. Is there any way to take care of this?
Re: Stain drying issue - help?
del schisler
>sure wipe it off I stain and what you have to do is keeping wipping it off for a while I do mine like in the morning and keep looking at it Than wipe it off After a while it will not seep any more I use old tea shirt stuff I bought a big box like 25 lbs of tore up shirts The finish will be ok just rub on the spots they will come off It is sopose to be 8 hrs setting time for stain that i use good luck
Lee Schierer McKean, PA
>You may need to dampen a rag with stain to wipe off the dots of stain. Porous woods like red oak and pecan can soak stain into the pores where it doesn't dry. Then as the wood warms up the entrapped air will push the wet stain back onto the surface creating spots. This is more of a problem in cold climates where the wood is cold and gets warmed up. What I do is wipe down everything as the piece is being stained and then come back several times later and wipe everything again until I quit seeing the little dots of stain at the pores.
Lee
Stephen Kirk
>Thanks, seems to be working. I turned the shop heat back on to help out the drying and I just have to keep going out every hour or so and wipe it again. Figure it should stop sooner or later. One or two spots where it darkened a slight bit, but they are likely only noticeable to me.
FredD
>a cloth dampened in Mineral spirits will remove the excess stain even if it has dried.
In the Winter I would suggest you keep the chat on for 24 hours, for a flat surface like your table a fan would speeded the drying process.
But you still need to check it seepage on woods Like Oak several times to be sure.
If you have a a larger area that has seepage and it really resists wiping with the cloth and thinner, run a card scraper over it lightly to hit the raised stain area and then wipe it with Mineral Spirits
FredD
