Rising to new heights
Ray Carson - Lawrenceville, NJ
>Here it is, the ladder project that almost wasn't. I started by cutting one stringer too short right off the bat and trying to realign the dados on the newly cut stringer was a tedious task. The other issue was attaching the top step. Screwing into the endgrain was a bear. I couldn't think of anyway to clamp it. With the multiple angles and so forth I really had to think a little about this whole project. This project was a challenge, to say the least. It was a challenge for ME.
The couple liked the Ebony accents and I wanted to add more Greene & Greene elements but they decided to keep it as simple as possible. Fine with me, the ebony isn't cheap.
I'm proud of the results and the couple is very pleased also. Oh yeah, the ladder was tested, (sorta) it held my 220+ mass.
Would I build another......probably not.
Ladder details:
9'-8" long, 14" wide at the top, 20" inches wide at he base
stringers are 1 1/4" x 3 1/4"
steps are 7/8" thick
top step is same thickness as the stringers to add a little bit of scale and "beef"
Every joint is screwed and glued.
Wood is Red Oak with a ZAR Spanish Oak stain. (clients choice)
The square plugs are Gaboon Ebony.
Three coats of wipe on satin "poly" for a protective coating.
(my camera is acting up so I apologize for the pinkish hues)
