wooden plate chargers
Jim Follette in Fayetteville, NY
>My daughter is getting married in the adirondacks in June and for the reception wants me to create some unique plate chargers (200), one for each table setting. Her idea is to have them each a wood slice, probably oak, complete with bark, 3/4" thick, about 14" diameter, that I can brand with a heart enclosing her and her fiance's initials. Anybody create anything like this?
Re: wooden plate chargers
Randy Johnson
>I would think that, unless the log you cut them from has been in storage for decades, they are all going to crack and split.
DAMHIKT
>That is a problem. I wonder if the logs can be kiln dried or if even that would take forever.
an alternative
Bill Tindall
>I have no idea what a plate charger is but I think I can put myself in the perspective of a guest at this affair, even in the Adirondaks where I manned the Kempshall Mt fire tower with my father. Whatever this thing is would go home with me, sit around for a bit and get tossed in the next cleanup. Perhaps a themed trinket for the guests could be found at one of the tourist meccas, Old Forge of Lake Placid, and personalized for the occasion.
2nd daughter put local honey in fancy jars she got off Ebay and labeled them in a wedding theme. Your daughter could do maple syrup. Any guest worth impressing would be impressed by a jar of fine mid-season maple syrup from the area. Once the honeymoon wears off this couple would come to appreciate some gift more lasting from your efforts, like a useful piece of furniture.
This advice should be discounted according to the fact that I offered each daughter a cash sum if they would quietly elope and avoid a wedding. Neither took me up on the offer which I thought showed a lack of good economic sense.
Re: an alternative
Bill Howatt
>A plate charger is a "plate" that sits under the plate at each place setting. Usually they are brightly colored or fancy.
I tend to agree with you that a small percentage will be kept on display, a larger percentage stuffed in a box in the basement and an even larger percentage will meet the fate you described.
I have a shell from my parents 50th with their names and dates on them on a shelf in a room in my basement. I often wonder the fate of the many others and tend to think mine are likely among a very small number still with the guests.
I've attended a lot of weddings over the years where I received little momentos and I doubt if I could lay my hands on any of them now.
Crass and nasty but another dose of reality.
Bill
>Jim, Post this on the Turning Forum (Look under MessageBoards, upper left) and you may get better responses.
Unlike Bill, I think I know what a charger is, but I would have to agree with him on everything else, including the elopement thing.
It is essentially impossible to dry a log so that it does not crack. Also, if you slice a cross section of a log, it will almost surely crack.
The only way I have seen to do this that promises some success is to make perhaps double the number of slices you need, keep them in order, slice into them from one side to the center, let them dry, the crack will open up, cut them apart, and glue various pieces back together to create circle again. By using closely matched pieces you make it more difficult to notice the joint.
Then you could sand the pieces into flat surfaces with a commercial wide belt sander or a Performax type drum sander. Or you could turn them on a lathe.
None of this addresses the fact that the bark tends to fall off.
Bill's right. Choose another technique or methods to create chargers or skip it and buy or make them a nice bedroom suite.
JB
>cut the blanks to ~1/2" and put into a vacuum chamber and SLOWLY reduce RH in the chamber.
depending on the species, a few days or so in the chamber will reduce the free water down to 8-10% with little warping that can be cleaned up with a run through a performax. super thin CA glue applied before drying will help to keep the bark on.
Howard Norman
>It sounds like a terrible idea to me. From my experience the chargers are going to crack and split before you finish all 200 of them. I would think that 200 pens with the first names of the bride and groom laser engraved on them would be a much better idea. But what do I know - I have never liked even attending weddings let alone making something for 200 guests that attended a wedding.
ti is the drying that is the problem
Bill Tindall
>It doesn't matter how it is dried, the problem remains. Wood shrinks about twice as much in its circumference as its radius when it dries. The stress generated is relieved by splitting a pie shaped opening(or two) as the section dries. White pine has less shrinkage than most species and a 14" pine might work. But I doubt you will get it dry in time. If you hurry the process it is guaranteed to split. It remains a pile of work for what seems like a small benefit.
