Joints Needed
Joints Needed
Joints Needed
Bob S
>Hi, I am making a cocktail table, with a glass insert. The side and front rails (for the top), are 2x2 square, and will come together in a 45 degree miter joint. I plan to cut a mortise into each face of the miter, and insert a piece of similar wood as a tenon. So now, I will have a picture frame top, and need to mount it to the legs.
I am not sure what type of joint to use here, I want the entire leg to sit under the table top, and the joint be completely hidden. I was considering a mortise and tenon, but do not want to mess with the mitered joint it will need to go into. Maybe a simple dowel peg joint on either side of the miter would be okay? Please help.
Re: Joints Needed
Re: Joints Needed
charlie belden
>If I understand it - you want a wooden 2x2 mitered corners frame with a piece of plate glass st down in it - to also act as the apron of of a table.
And you want to attach the table legs directly to the mitered corners of the wooden frame.
How about if you connect the legs with an apron - and join the top to the apron - with dowels or loose tenons? Leaves the mitered corners of the glass's frame alone. If you want to semi-hide the apron you can set it back since the wooden glass frame is 2" wide. Will also give you a lot more glue surface area connecting the top to the support - legs + apron.
Re: Joints Needed
Re: Joints Needed
Ed Mulligan, Cape Cod
>The classic joint for this situation is the three way miter. It's quite difficult to make well. One's bad enough; getting 4 looking good on the corners of a table is a real challenge. Never tried it myself and don't know anyone who has.
If you don't like Charlie's idea and want to go with dowels on the leg up into the horizontal pieces, consider putting in stretchers. The stretchers will add considerable support to the legs and take some of the stress off the dowel joint.
Re: Joints Needed
Re: Joints Needed
Bob S
>Guys, Thanks for the input. I cannot attach an apron as I am trying to duplicate a table that i am copying from Crate and Barrel. I will try to upload a photo later. Stupid me, didnt think to look at how they possibly attached legs to top.
The Triple-Miter joint sounds scary. Also, There is a lower rail, halfway up all the way around the table that will add stability. Picture later. Thanks.
Bob
Re: Joints Needed
Re: Joints Needed
Neal in San Jose
>The three-way miter joint is a classy joint that solves several problems. There is no end grain showing, which for the table you describe would be an advantage, and all of the wood movement occurs in the same direction which results in a joint that doesn't constantly try to rip itself apart.
It will test your craftsmanship, but is well worth the effort. If you can get your hands on Yeung Chan's "Classic Joints with Power Tools", he shows a very straightforward method that uses just the table saw, and he greatly simplified it by using floating tenons. You will have to cut pockets for the floating tenons with either a hand chisel or hollow chisel mortiser, but it is a fun joint to make.
Re: Joints Needed
*photo added*
Bob S
So, here is the table i am trying to duplicate. I don't think a triple-miter is necessary, nor would it fit in with style. Sorry it took so long to add picture. I think top fram will simply rest on bottom frame with a Dowel Peg (3/4" or so) linking the two frames.
Next issue: Mortise and Tenon on the side rails to legs, probably is necessary, but they need to be angled as legs are tapered. No big deal i guess. Any more thoughts?
Re: Joints Needed
Re: *photo added*
>Yep, a dowel would work. 3/4" is good. Two dowels or a couple of loose tenons or dominos would be even better.
Hope we will get to see your table when you finish it. Good luck!
