Cleaning old wood?
Cleaning old wood?
Cleaning old wood?
>I've been asked to clean an old pine toy box. It was built in the early 1920s. I'll also be repairing it.
It does not appear to have a finish on it. It is also quite dry. I was figuring on going over it with an abrasive pad and some mineral spirits or thinner. Unless someone has a better idea. It is winter and I really don't want to go outside :\ .
Re: Cleaning old wood?
Briwax
Andy Wright - Allen, TX
>One thing I have done to several antique items is go over them with Briwax.
To apply it, I rub it in with 0000 steel wool then buff it out. On old pine it creates a nice shine, will moisturize the wood, and enhances the existing patina. A lot of antique dealers use it on items before displaying them in their shops
Still a lot of grime and dirt..
>I was thinking about cleaning it. I was also thinking about Murphy's Oil Soap and water, but the wood is so thin and old (less than 1/2").
Re: Briwax
>It may sound counterintutive, but I actually just dust pieces off and then use the Briwax without cleaning. The grime "disolves" as you work the Briwax in with steel wool. If you've never worked with it, it is hard to explain, but I have had good luck with literally taking a pice "out of an attic", getting as much dust and dirt as I can off with a damp cloth, and then going after it with Briwax once the the wood is dry from the cleaning. if there is still dust and gunk left on the pice, it gets worked loose by the wax and then goes on the rag when you wipe off the excess. A LOT of antique dealers use it because it gives such great results without a huge effort, and it doesn't destroy the patina
This is an old desk I bought several years ago. When I brought it home, it was dusty, dry, and had several large bare wood areas on the top and the bench where the finish had rubbed off. I dusted it off with a rag, and then went over it with a light colored Briwax (no cleaning) and it totally transformed the desk
FredD
>If the accumulation isn't crusty, then thinner will work fine.
If it has any patina on it that you want to save, Mequiar's
makes a cleaner /polisher for the auto finish industry that is really good , it does both cleaning and polishing with a wax that seems to disappear as you rub it in.
FredD
Re: Still a lot of grime and dirt..
Keith Newton----Little Rock, Arkansas
>I would start with a coarse stiff brush and compressed air to loosen and remove the dirt. Not a wire brush, but either a natural bristle scrub brush, or a newer plastic version.
