Getting Bakc In The Saddle
charlie belden
>After making all the "shop furniture" I needed - and could fit in the shop - I had the tools, machines, wood and the basics skills for making "house furniture" -my reason for getting into woodworking in the first place.
Then it was necessary to bring my elderly father out here - along with his house full of furniture - rosewood chinese furniture - really NICE rosewood chinese furniture. The 850 sf unit of my duplex got stuffed - to the gills - with really nice pieces - leaving no room for anything I'd planned on making.
Now there's only so many boxes - jewelry boxes, toy boxes, puzzle boxes - and kids toys you can make before that gets really old and boring. So I got a JET mini/midi lathe - for turning some magic wands for neighborhood kids. Took a while to get comfortable with the idea of spinning a chunk of wood at what seemed like ungodly speeds, then poking sharp steel tools at it - but I got over that pretty quickly.
Can't believe all the stuff that you "need" once you get a lathe - but that's a whole 'nother story.
I've recently gotten back the WHOLE place - another 1300 sf - and moved all the rosewood chinese furniture into that space. So now there's room and a need for 16 feet of shelves above, cabinets below, two entertainment centers, a desk, a few end tables and a coffee table - and a couple of twin bed heaeboards and frames
Having now cleared off the layout/ assembly bench, the infeed and outfeed tables for the SCMS and uncovering my combi (Robland X31 five function 1100 pound beast) and all the stuff that accumulated on my REAL woodworking bench - I'm ready to start doing some flatwork again.
Then I fired up the 3 hp 10" table saw - with the regular kerf Forrest WW2 blade - and the hair - that I don't actually have anymore - stood up on end and the adrenaline began pumping. That's a LOT fo really sharp carbide teeth going by at 5000 rpms!
To put off actually feeding wood to all those spinning teeth, I shut it down and checked the saw's set up. Blade parallel to the miter slot, fence parallel to the miter slot. blade and fence square to the saw table - STOP switches - there are THREE on the X31 - all easily accessible - push sticks and a GRRRIPPER at hand - it was time to do some table sawing - after a four year hiatus.
The hair - that I don't actually have - still stood on end - and the adrenaline came back. I took all the usual precautions when ripping - the first cut went as expected - but that little voice was still saying "Are you out of your mind!? You're going to push THIS piece of wood - into THOSE spinning teeth - even with a push stick?"
I'm guessing that the same sort of thing will happen when I fire up the 12 joiner/jointer and start joining the first board.
If YOU'VE gone of a woodworking hiatus, how long did it take you to get back to feeling comfortable - yet not careless or complacent - with your cabinet saw and joiner/jointer?
Re: Getting Bakc In The Saddle
Rod Peterson�Ormond Beach, FL
>Did I parse out of your post that your father passed away? My sincere condolences if I inferred that correctly.
Rod
Re: Getting Back In The Saddle
>Charlie, I am 60 and started woodworking in high school when I was fourteen. Over the years, life has gotten in the way several times and there were interruptions. As I recall, it was like riding a bicycle. You don't forget, but you do get a little rusty. I think it was a couple of days and it seems normal again. Actually, I have a shaper (a small shaper with a half inch shaft) that I don't use very often. There is something about that machine that gets that same response from me every time. I'm not really afraid of it but I really don't like it. Something about that Invisible cutter taking off the edge of the board just gets my juices pumping. I think it through and double check the setup almost to the OCD point and then make the cuts. Oddly, don't get any where near the same response from the router table.
Be careful. It will be back by about Sunday.
Jorge Casta�eda
>Charlie, for a moment I thought you were mounting your steed and riding into the sunset.
What you got it is actually a very healthy thing, a great deal of respect but don't let it makeyou shy away from the work at hand. What could be more scary than a chain saw? at least the table saw and the shaper sit in there, but with the chain saw we are out there wielding it up in the air cutting this and that. But all along before every cut, I keep reading everything, where is the branch going to go? etc, etc, Always pondering the risks, but keep going.
I'll be 76 come spring, and have been working professionally with wood virtually everyday for the last 44 years, and still digit in deca mode after working in shipyards, and construction sites, and as I mentioned, in the woods.
Do your thing and never loose that healthy fear.
Jorge
Barry, I know how you feel about the shaper, the only way I used it was with a power feed. I sold it years ago...
You guys need to suck it up, and dream woodworking
Keith Newton----Little Rock, Arkansas
>Early this morning, I woke up from a dream where a friend and I had been a long way off working. He was a pilot with his own plane. On the way back home, he spotted smoke from a forest fire, and said something like hey Buba lets have some fun.
We got a big trill out of flying through flames from a canopy fire on an up-slope, just above the treetops, which were blinding to fly into. After coming out the other side, I looked back to see a trail of black smoke.
Why the fuel tanks didn't blow, or the engine didn't stall from lack of oxygen can only be explained by the fact that this was just a dream.
Anyway, I unbuckled to explore for the source, only to find the tires were on fire. I couldn't extinguish the fires, but the good news is that after they burned away, I was able to jury-rig both of our finish sanders in place of the tires on the landing gears, so we were able to land without having to slide in on the belly.
You always have to keep your cool and be willing to improvise to make things work. At least that is how it works in my dreams. K
suggestion for the path back
Bill Tindall
>Set aside that blade and install the best quality thin 7 1/2 or 8" blade you can buy. The comfort factor will go up considerably. I have kept such a blade on my saw for the past 4 years. On the rare occasions when I need to use a 10" blade it indeed is an occasion to pause and redouble safety efforts. I become grateful that I discovered the merits of the small blade for routine work.
In case the benefits are not obvious- much less cutting force leading to enhanced control, less noise, less dust. In 4 years I have never had the small blade throw anything. In fact I have gotten a bit careless about this aspect of the table saw so that I need to be extra careful when I have to use the larger blade.
Apparently the notion of using a small blade on a 10" saw is so radical most won't even try it. Those that have in our club have quickly been sold on the idea.
7 1/2" AND Thin Keff Blade
charlie belden
>Bill:
For thinner stock and small stuff I usually did use a 7 1/2" thin kerf blade - a 10" full kerf tears up 1/4" ply - and the smaller, thin kerf blade is fine for ripping up to about 1" thick stock - it it isn't too long a rip cut -and the wood behaves.
But for cutting up 3/4" ply, especially when working with half sheets, the thin kerf can, and typically wil, flex if you're not really careful.
The Robland COMES with a riving knife - for a regular kerf blade - that raps around the top rear quarter of the blade - real close to the blade. That riving knife is my Security Blanky. With it on the saw I feel much more secure when making cuts - because it keeps the wood at the back of the cut AWAY FROM the teeth coming up out of the table - that want to HURL the wood back AT ME.
I can't use the full kerf riving knife with a thin kerf blade. I probably should get around to making one for thin kerf, though I'm not sure it would be strong enough to not flex. And if it can flex - it can't do its job of keeping the kerf open - and the wood away from those rear teeth - where most kick backs start.
Anyone with experience with a thin kerf riving knife used with a thin kerf blade?
Re: 7 1/2" AND Thin Keff Blade
FredD
>Charlie ,
if you running a quality ten inch general purpose blade on your saw it shouldn't be "tearing up 1/4" "plywood".
Some veneers will have a cleaner crosscut with a zero clearance table insert , but other then that , your blade should be giving cuts that are shiny smooth with no fuzz on the cut edges.
FredD
Jorge Casta�eda
>Charlie,
I have used 7 1/4"a lot, mostly with a new blade for final cuts on furniture. Not for the earlier stages.
In my experience, the saw blade covers and splitters or riving knives are more trouble that they are worth, they get on the way and get you in trouble.
Most of the kickback situations are due to compression wood, a case where the riving knife would help, and operator error, either by letting the work move away from the fence and most probably by the fence not being perfectly parallel to the blade.
I do not bring big pieces of plywood to the saw, I do those cuts with a skillsaw and guides, ad occasionally I do refine these cuts on the table saw. (As the veneers for plywood were made by peeling, there is lots of short grain and as the "good" veneer is infinitesimal it may crumble more with the skill saw.)
ymmv
Jorge
