Re: Fluorescent light ballast
del schisler
>take apart and take the ballast to a electrial supply shop ?? Or get the name of unit and town go to google and do a search for the model and brand name and town Chase it down with google
del schisler
Tom MacGregor
>There should be a wiring diagram on the ballast - it's designed for the number and type of bulbs in the fixture. You can change it for a new one of the same type with a pliers style wire stripper and a few small blue wire nuts. Cut the wires from the old ballast leaving some of the old color coded wire attached to the lamp holders. Connect the new ballast wires to the old wires with the wire nuts. If a fixture used the older four foot bi-pin T-12 bulbs I buy a ballast for the newer more efficient T-8 bulbs and rewire the lamp holders according to the diagram on the new ballast.
Depending
Bill Houghton
>Depends partly on how close you are to a good or even moderately good electrical supply shop that sells to the retail crowd. You need the right one, but they're fairly standard components. You certainly are unlikely to need the factory original.
I concur that it's worth upgrading to T-8 bulbs. Not only more efficient, but they go on instantly and hum less.
Phil Joines
>I've run into a few oddballs that don't match anything being made now but it doesn't happen often.
