Re: Wood Storage Rack II *LINK*
Grant in Iowa
>OK, now that I am registered again...sorry...
Ed,
I designed and built a rack for use in my old shop to store lumber as described in Articles (see below link).
it is a nice rack, designed to be mounted to a wall, while not putting too much pressure on that wall (thus the angled design placing the center of gravity over its base).
Now, Page 2:
I have since moved, taking the above described rack with me to install along the wall in my new shop. I have also built another next to it one based on the same basic design. The new one is a free standing A-frame version (thanks for the basic idea, Ellis!) with sheet goods storage incorporated.
here's a photo of that rack:
I find the shelves make lumber easy to sort and access with a short step ladder. They are very sturdy. I suggest drilling holes in the uprights to receive the pipes about every 8" or so vertically in order to allow flexible shelf sizes. I made this A-frame rack 8' long with 16" centers.. which I have decided is a bit overly built...perhaps 24" centers would be plenty.
The tilted back design helps keep things from falling off, and also keeps the center of gravity over the base regardless of how you load it. In times when you don't have a lot of lumber on hand, you can load the lumber higher (judiciously) and remove the pipes on lower shelves to provide extra space for other things.
I buy the pipes precut at a local steel supplier. They are 1/2" black iron and vary from 16" long on lower shelves to about 22" long on the upper shelves to save floor space. I think the entire project cost me about $270 three years ago and stores around 2000 board feet of lumber.
The added upright at the top is a series of 2x4"s I added with heavy duty (not deck) screws to allow more lumber to be stored. The main uprights are joined at the top with two 3/8" carriage bolts per a-frame. Don't put this type of thing together without using heavy hardware!
I should add that not pictured is a sheet of plywood on the inside of the a-frame and screwed to each a-frame to prevent the assembly from racking.
See the below link for construction details and hole size, etc... the link is for the wall leaning version, but it should give you the idea. I don't have a plan for the a-frame version but you should be able to figure it out from the photos.
Regards,
Grant in Iowa
Grants lumber rack in articles section
