OT Computer problem
OT Computer problem
OT Computer problem
Jim-IL
>Couldn't turn the computer off last night, just came down to the blank desktop with only the wallpaper showing. I turned off the monitor so the light wouldn't obstruct our sleep. When I turned it on this morning, same thing, just a blank screen. Any ideas?
Re: OT Computer problem
del schisler
>sure push the off and on button PUSH in and hold it their it will shut off Don't let the button come back out hold down or in May take 10 sec to shut down good luck
Jim-IL
>Thanks much, Del. Did what you said and it shut down and then rebooted without a hitch.
John McGaw
>You should be able to find a setting which tells the computer what to do when you press the power button. It sounds as if yours is set up to simply go into sleep mode. This setting in XP, for example, is under Control Panel -> Power Options -> Advanced (even though it isn't really advanced at all). But as you were told, pressing and holding the power switch for a time sort of bypasses all options and really does shut down the computer.
del schisler
>if you go into the power icon and go advance and look it should be set to shut down I bet it is set that way sometimes the comp get a brain fart and won't go all the way to shut down Also good mantainence is to do scan disk and defreg from SAFE MODE only It you do it any other way Their will be program's that are running and don't get defreg If you haven't done this for a long time or never it may take a long time to do this ??
