We value your privacy.
>I bought a 1/2hp motor from a vendor on EBay. Before I bought the motor, I wrote and specifically asked if the motor had a flat mounting plate, explaining that I had to mount the motor on a flat surface. The reply was, "...yes, it has a plate for mounting."
When the motor arrived today, I found that there was no mounting plate at all; the motor is totally round except for the wiring junction box and the capacitor...no way to bolt the motor to the flat surface.
I don't know a lot about this stuff. I have written requesting a full refund, including shipping (I was lied to about the motor). If that doesn't work out, though, I am a bit stuck. So, is there a way to attach a mounting plate to a round motor so I can bolt it to a flat metal surface? The motor is a 1/2hp Leeson TEFC, C56C frame if that makes a difference.
>It sounds like you have a face frame mount motor. There should be mounting holes on the end frame near the output shaft. You might be able to find or make a right angle mount that will attach to those mounting holes.
>call leeson motor and give them the munber of the motor and they will sell you a base If your motor look's like this This motor has a start cap and run cap on it Your's has one cap ? Doesn't matter call them Here is a pic of a motor with base and the phone number is their also
Not totally lied to as the C face motors do have a flat end bell and can mount on a flat plate. C face do normally have a centering ring to mount direct to a gear box, pump head, etc. but still basically flat.
As Del noted you might be lucky as some motors are dual mount and may have tapped holes to bolt on the rigid foot mount. If you find two bolts or two screwed plugs in the housing you may be able to bolt on the base. There is no uniform standard for the bolt pattern on the housing but once the base is mounted the foot matchs all other NEMA 56C frames for pattern even if by slots.
If you have the tapped holes you can buy the base from Leeson and may get lucky and a motor shop give you one from an old motor. Best to take it along and check the housing pattern to what they may have.
Adding a home made base by using the end bell will depend on how you are using the motor. The shaft projection on a C face and straight foot mounted can vary by end bell design.
>You have a NEMA size 56 face mount motor, but you already know that. I recall seeing a universal mount that attached to the motor using 2 long hose clamps and a pressed metal base. These were advertised in Pop. Mech. and Pop. Science magazines. I did a quick search and couldn't find one on the internet. Your other alternative would be to drill the spot welds out of an old motor base and have a welder spot weld them on your motor. This is tricky but I have done it. You just have to avoud adding too much heat to the motor shell.
>I will give them a call to find out a price. After all this, I wish I had just bought a new motor at TSC. I'll end up having as much money, and far more aggravation, involved because I tried to save a few bucks.
>Yes, Lee, there are mounting holes on the face. That is probably what the seller was referring to in his reply. Unfortunately, my question was specific, asking if there was a bracket on the motor that could be mounted. Maybe not intentional, but certainly not an accurate answer after my specific question. Lesson learned on my part...never buy from an ebay seller with 0 feedback. I will probably end up going the PayPal resolution route; I have yet to hear back from the seller who answered immediately when he was looking for my money.
>Joe I bet you could fabricate some thing like that pretty easily. You can buy hose clamps big enough at Lowe's. If not, you can add a couple together. A 3" and 4" can be strung together to make a 7. Doesn't seem like that would work to me, but it does. A metal plate with some slots in it for the stripes and some short piece of angle epoxied to the plate and you are in business. Just arrange the straps to miss the capacitor.
I have a 2 hp C face motor I have been thinking about putting on my bandsaw, but it would require a base and it runs at 3450 and the one on the saw is 1725. So, I would have to make a base and change all the pulley and the wiring and switch and the breaker. Seemed like too much to do. Better to get the right motor to start with.
