OT : DIY Carpet . . .
steve mackay
>Without getting into types, styles, grades, etc of carpets, just a general question . . . can it be installed by the common human ? Or would you wind up renting / buying "carpet specific" tools (that would add up to the cost of instilation) ? I can manage most projects but carpet isn't on my resume . . . yet. I'll sit LOML down to read your responses in case I need to bail on this one ! LOL ! Thanks much !
Re: OT : DIY Carpet . . .
Dan Donaldson
>It probably can, but I would not try it unless I knew someone that knew how to do it. From watching installers in my house over the years, it looks like there are quite a few tricks that would make it difficult if you didn't know them.
>As a builder I have over seen the installation of thousands of yards of carpet. I have personally done about everything involved in building a house. Carpet not so much.
Perhaps I am just slightly intimidated or maybe its because it looks like it would be painful on my aging knees, but I have no urge to do carpet.
There are some specialized tools. Stretchers, equipment for seams, edging trimmers and even knives. (Its the knee bump stretcher that makes me cringe.) Obviously, I don't even know the correct names for all the tools.
Also, I think these guys work cheap. If you shop around you can get a room done for $99 and a whole house for $299. Just wrestling the big roll of carpet into the house is worth something.
Ps, Dan is right....
>It looks easy when the pros do it but there is much to know that is not apparent. And it may be easy to ruin the whole thing if you don't know the tricks.
Agree
Nat Robison
>I had 2 installers put in 500 sq. ft. plus a flight of stairs a few years ago. Pad, tack strips, all of it took about 2 hours. I'd rather spend money like that and save elsewhere. Like it was mentioned, you're not paying plumber/electrician rates for carpet installation.
You can always look into the DIY carpet squares that they sell at HD and Lowe's but depending on the number of cuts, it might not be worth it.
Joe Pack
>Let the pros do it. And insist that power stretchers be used! That knee-bump thing is a joke with most synthetic backings. Not enough force, zero constant force. The "stretch" is one bump forward, half a bump back.
Something to consider...buy your own carpet direct from the Georgia area mills and hire your own installer. Even with delivery charges, we saved 40% of the cost of carpeting over store prices. Same carpet, same quality of install, big savings. Google georgia carpet and you will find lots of big, quality suppliers. Find the brand/model/color you want in a store, then check prices with the store and the "buy/install your own" method. In my case, I thought $1000 was too much money for someone to make a phone call for me.
Jason Roehl in Lafayette, IN
Good points above.
>I don't know what your market is like, but around here, installation varies around $3/yd--if you hire the installer directly. Carpet retailers will typically charge $6 or more per yard for installation, then beat the installer down to $2/yd or so.
So, what Joe said is good advice--buy the carpet, decline installation, and hire the installer yourself based on recommendations of people you trust. A poor installer will beat the snot out of your baseboard, either when they nail down the tack strip and use the baseboard as a bank board, or when they use their tucking tool, scraping up the baseboard.
All that said, you can rent all the tools necessary to DIY, but unless you've watched it done a bunch and asked a bunch of questions of experienced installers, I doubt you'll be happy with the final install.
Jason
Make sure tehy are insured
Lee Schierer McKean, PA
>My son's FIL bought carpet through a carpet dealer. The installer showed up, went in to see the location of the install which was upstairs. The installer went downstairs, got the roll of padding and came back, refusing any help to get it up the stairs. He struggled to get the padding into the room. Once the padding was down the installer took down the door to the room and put it in the hall way and went out to his truck to get the carpet. Once again he refused any help. As he turned the corner at the top of the stairs he bumped into the door he had removed a couple of times as he maneuvered the carpet into the room. Some of this included pulling the door along the hallway and pushing it tight to the wall with the end of the carpet that was still trying to make the turn.
Just as the carpet went fully into the room, the door, which had been pushed tight to the wall and moved toward the stairway tipped and fell down the stairs. The door hinges and latch stuck down and as the door slid down the steps, it alternated between banging the treads with the door handle and gouging them with the hinges. At least a dozen hardwood stair treads were badly damaged. The damage was extensive. Needless to say the carpet supplier was also asked to replace the treads at no cost to the home owner.
Re: OT : DIY Carpet . Read this one . .
del schisler
>i didn't read the other responce But you need carpet tack strips which comes with stud nail's installed in it Now comes the pad Now a Hot gun to seam the carpet togother or sew it ?? here is a link on that
http://www.ehow.com/how_5459770_make-professional-carpet-seams.html
Now you need carpet streachers Some good and big Scissors to cut Than you have to watch and run the carpet the same way or it will look bad one way It won't look right Lot's to thank of I would let some one that in the busisness to do it If it a glued carpet than i wouldn't even think about doing it good luck
FredD
>I would leave the carpet laying to the guys that do it for a living
That being said , some of the replys had good points , Joe has the right idea in shopping the carpet and hiring the installer yourself.
Some are better then others and it pays to ask around for right guy.
You need to have a conversation prior to the install with the installer about who will be responsible for cutting the doors to accommodate the new pad and carpet and express your concern about having the job look better after it is done then before, which means no dings in the paint, base or door or casing or hallway walls.
Leave his choice of stretching tools up to him, as long as the carpet is tight and free of wrinkles , that is all that matters. If there is pattern matching ask him about it BEFORE you buy the carpet and also have HIM
tell you how much to get.
Follow this and you should have no trouble.
FredD
I gotta say . . .
steve mackay
>I think I've just dodged a bullit thanks to all of you. This might be the very first subject on WC I've seen when there was not one vote of confidence. All other sunjects AT LEAST get a "Sure, you can do it." I'd have tried it if she insisted but, after rading your responses, she has seen the light. Its only one square room with no closet so we'll "pay the man". WHEW ! Thats a load off !
