Severe moisture no more
David Frame
>I accidently came across a solution for my moisture/ rust problem. An old friend sold his carpet business and I was able to get a professional dehumidifyer free.
Before I first started woodworking at 14 years old, I was a pump jockey at a gas station where the owner of a marine seating company would get his fuel at 19.9 cents a gallon. I asked him for a job, and he agreed to it stating he needed someone to do some heavy lifting at his place of business. I caught the woodworking bug and the rest is history, except the story behind it.
From that point, I was taught to etch aluminum, painting AC exterior plywood with epoxy and radar stands made of an aluminum alloy and tig welding. Next, the person that did the woodwork had gotten ill and I took his place. I was fabricating basic flat �� plywood seating with radiuses for offshore crew boats, workboats, tugboats, and ferries. In large crew and workboats, they have a second and third deck, and sometimes a fourth deck where we built booths on an angle because of the way these boats sit in the water. For a 14 year old, this was not exactly easy. However, I did get the hang of it.
This company was good enough to teach a child painting, woodworking, foam work for the upholstery, sewing, and uphlostering, and to use a number of solutions for hardware . The reason I tell you my story of my artistic backround is because, the man that hired me and taught me all of this work, came up with a solution for removing the rust from my cast iron tools. He said to use 3M 5 Way Penetrant Solution heavily and cover the cast iron with a bed sheet. Leave it on the iron for a week and remove the sheet slowly. Unbelievably, there was no rust left. The iron tops felt like the gunk that are on new cast iron tools. I wiped the tools down with turpentine and let dry.
The owners name is Edward A. Cannon Jr. The company name was Eacco Marine Inc. He changed it to Eacco Inc. because he and his workers are fabricating aluminum and stainless doors and doing less and less woodwork, painting, and upholstery.
I�ll will be forever grateful to Mr. Cannon for teaching a kid that was wet behind the ears and turning him into a man. This seems like a long story, but I needed to tell it to acknowledge the man who taught me all the basics of working with ones hands, and about life.
David L. Frame Jr.
dframe01@hotmail.com
