200+ woodworking book reviews
Fretwork Tray
Re: Fretwork Tray
Re: Fretwork Tray
FredD
>Lot of work there , sanding and getting a smooth finish in all of the holes.
what did you use for the contrasting panels?
FredD
Re: Fretwork Tray
Text for Fretwork Tray
Bill Tindall
>Well that was strange....something crashed and the picture uploaded but the text didn't.
This piece involved a lot of fretting, mainly because I had never done anything like it before- fret work, bracket feet, inlay, chemical staining.
The assembly is quite complex. The inlay, alternating bands of satinwood and mahogany, is glued together like a butcher block and then sliced to make a veneer band. This band is applied to a backing which comprises the center of the side. A strip of solid wood is glued beneath this inlay strip. A strip of 3-ply homemade plywood is glued atop the inlay strip for the frets and finally a strip is glued around the top to hide the plywood edges. The bottom is snug fit homemade plywood to add strength to the piece. I found some nice ribbon stripe to resaw for the bottom.
Someone, I can't recall who, suggested the frets be cut from "plywood" to add strength to the delicate fret work. Indeed, this approach added strength, at the expense of needing to deal with the plywood edges. Some of my catches with the fret saw would have undoubtedly broken some of the fret work had it not been plywood. Normally such a tray would be dovetailed together but I chose posts to hide the plywood edges.
Staining is a problem because one wants the stainwood to remain unstained. The traditional way to deal with this problem is to stain with some sort of basic material- lye, lime or ammonia. I chose ammonia. Now that some sun has hit the piece it is browning up nicely from its initial red hue.
Re: Fretwork Tray
Re: Text for Fretwork Tray
FredD
>"This piece involved a lot of fretting"
There's a double entendre if I ever saw one.
I made three layer mahogany corner brackets from 1/8th thick wood for two Mahogany hall tables and you could not see the three layers after assembly and finish.
FredD
Re: Fretwork Tray
Plywood? Is it dishwasher safe?
>Sorry, Couldn't help it.
That's a really good looking tray. Huge amount of work. Congratulations on a job well done and the patience to make it happen.
