Shoe Brushes
Shoe Brushes
Shoe Brushes
Gary Smyth
>This week I latched on to a box of really nice horsehair shoe brushes. They are at least seventy years old and seem to me to have almost twice the number of bristles I've seen lately in similar items. The problem is that the bristle bottoms are heavy with shoe polish. On a couple of the brushes several bristles have very small "BB" clumps. I need to remove the polish to allow the brush do its work. Polish is essentially wax but I do not want to dissolve the hair or have the bristles fly out to the side (as opposed to straight down) of the brush if I use detergent. Anyone have any ideas. Acetone or thinner combed through? Steam? Wire brush? What dissolves wax?
Looking for alternatives.
Re: Shoe Brushes
Mineral spirits dissolve wax
Bill Houghton
>I would experiment a little, though, with the scruffiest of the brushes.
You might, once you get the wax softened up, be able to comb some of it out - a paint brush comb, available from your local pro's paint store, probably best for this.
Odorless mineral spirits are less ferocious than odorous - at the cost of taking longer, the milder odorless might be better.
Re: Shoe Brushes
some ideas
Roy Anderson
>Here is a brain dump. Experiment around and see which one works best.
Soaking in hot water will loosen wax
Virtually any petroleum solvent will dissolve wax. Mineral spirits, naphtha, WD-40. Note: WD-40 does not contain fish oil or silicone as is sometimes rumored.
Warm vegetable oil, like canola oil or soybean oil, will dissolve wax.
Soaking in full strength household ammonia cleaner will dissolve wax
After you have it loosened, comb out with an old comb
Good luck and let us know which method works best.
Re: Shoe Brushes
wax solvents and techniques
Bill Tindall
>Any hydrocarbon dissolves wax- mineral spirits, toluene(best), turpentine and the hydrocarbon will not affect the hair(think paint brushes). The wax will dissolve much better if the solvent is warm but of course this increases the flammability concerns.
However, I am not sure this is the way to proceed. The adhesive that holds the bristles in may dissolve, or the finish on the brush. Maybe if you just dipped the ends into warm solvent it would accomplish the task. I would first try getting the brush warm and see if I could rub/comb the excess wax out. The warming could be accomplished with a hair dryer.
Re: Shoe Brushes
Re: wax solvents and techniques
Art Luczynski
>;) Warm (hot) soap and water should clean them just like washing your hair rinse all the soap rinse out with warm water and let them dry.
Re: Shoe Brushes
Re: Shoe Brushes
FredD
>I think I would take a paper towel and lay it in the Microwave with the worst brush on it and set the Microwave on it's defrost cycle and see what happens..
The wax will surely melt and run down.
Combined with clean up with a solvent should leave the bristles intact.
You never know until you try ;-))
FredD
Re: Shoe Brushes
Re: Shoe Brushes
Art Luczynski
>I learned this form an old shoeshine man in the 50tys when everyone shined shoes. Soap and warm (hot) water works I have white empire brushes that old and that is how I have cleaned them many times it works.
Art
Re: Shoe Brushes
Jesper, Denmark
Re: Shoe Brushes
Jesper, Denmark
>Simple, Wash the brushes in hot water with a little detergent and let dry - good as new.
Standard Operating Procedure.
Re: Shoe Brushes
Re: Shoe Brushes
Howard Acheson
>What do you intend to do with these brushes? How clean do they have to be?
Re: Shoe Brushes
Re: Shoes.  But I'm particular.
Gary Smyth
>Just get them back to what they were intended to do
Re: Shoe Brushes
Jesper, Denmark
Fire Hazard!!!!
Jesper, Denmark
>You might find that the microwave will set the brushes on fire - be careful.
