Veritas - Innovation in Tools
Block Rabbet plane
Block Rabbet plane
Block Rabbet plane
BILL P
>Hello woodworkers,
I'm looking for a nice block rabbet plane any suggestions.
Thanks, Bill
Re: Block Rabbet plane
Re: Block Rabbet plane *LINK*
Andy Lincoln,in Dearborn MI
>Bill,
If you are looking for new off the shelf the L-N 140 is quite nice.Harder to come by and probably just as expensive is the stanley #140 upon which the LN is based ,you'd have to shop Ebay or used tool dealers for that.
also the Lee Valley skewed rabbet set is very nice ,very functional as well.
Andy
Skewed rabbet at LV
Neal in San Jose
>I have a couple of thoughts: first, you might consider posting this over on the Hand Tool forum and second; can you tell us a little about your intended use and maybe your budget? These planes tend to be a little specialized, and wouldn't be in my first dozen planes to acquire if just starting out. They aren't too limited in what they do, tho, and I sometimes do use one of mine as a "normal" block plane if it is closer to hand. I don't do that often, tho, as they tend to be a lot "fussier" to sharpen.
I have two rabbet block planes, both metal; a Lie Nielsen #60 1/2 R which is out of the budget for many people, and an antique Ohio Tool 060 1/2 R, which if it didn't have a small chip out of the back end, would be obscenely valuable. I'd recommend either, altho good luck finding an Ohio Tool! The LN works better, anyway!
Roy Anderson
>I agree with everything Neal said.
1. Try the hand tools forum
2. The Lie Nielsen 60-1/2 block rabbet is to die for, but pricey. I've been waiting for it to go on sale. No luck.
Here is a link to the Lie Nielsen plane
block rabbet plane to die for
Randy Johnson
>I've never bought any LN bench planes (Stanley 2-8) but I have several that are harder to find as an old (read cheaper) plane.
The 60 1/2 was the first LN plane I ever bought and it is the reason I have some of the others. When I picked it up I knew I was holding something out of the ordinary in my hand. If I couldn't get another one I wouldn't sell mine for a thousand bucks. Everyone should have one.
BILL P
>I want it mainly for sneaking up on tenon sizes. Price (you get what you pay for) is a factor, as in a longer wait time to purchase or more overtime. Since I work at least 6 days a week the latter is the last resort. I like the Arts & Crafts style of funiture and as you know, lots of mortise and tenons.
Dave Bair, Eaton Rapids, MI
>For M&T work, you want a shoulder plane. LN and LV both offer superb versions. I use a much, much cheaper Stanley #92.
LV Medium Shoulder Plane *LINK*
mdclor
>I have this one and like it a lot for fine tuning tenons. It was very sharp out of the box and has remained so with very little touching up.
Link
Tony - Memphis
>I've had the LN 60 1/2 R since it came out (pre-order deal) and I really like it. It has been a great tool to have. I use it for cleaning up tenons (ie fitting) and other tasks. The only complaint I have is that it is a little tough to get the iron square to the bottom of the plane. You have to grind it real good and square and then tweak it a little after you install it. Not unlike most other planes really.
I've not used any other rabet block planes, so I can't give any comparison.
Tony
