We value your privacy.
>I have my eye on a cherry tree that is growing in the edge of the woods. Its tall for a cherry, probably over forty feet and maybe 20 to 24" at the stump. It is leaning out of the woods and laying on another tree. It's probably leaning three or four feet and has a curve in the log. My question is what affect the curve would have on the lumber if I have the tree cut and sawed? Would there be internal stress/reaction wood whatever?
>Do you know how long the tree has been leaning? If it had been standing straight for most of its life, that wood should be normal.
As for leaning against another tree, this may take the strain out of the equation. As for seeing the reaction wood in cherry, it isn't hard to see and avoid including in your work.
If when you cut the tree, finding the pith off center might be an indication of grown stress, while centered would probably give more likely good results.
>If you don't know how to cut a leaning tree find someone that does. They are easy to split and that will ruin a lot of wood, and ruin your day if they split inconveniently.
I don't deny the concept of reaction wood and the like but I suspect that it is less an issue than some make of it. Of the thousands of bdft of lumber I have planed and a lesser amount worked I have never encountered a piece of wood that was not usable except for obvious defects like knots, rot, etc.
>I have been thinking aobut cutting it. It's on the family farm so I can get it free. But free stuff is rarely free and sometimes not even cheap.
One of the the thinks holding me back on this one is it is overtaken with poisin ivy. Major vines growing on the tree. I'm scratching thinking about it.
How would you saw it? I know a guy near by with a band mill.
>I've been told that poison ivy is a real pretty purple color if you care to work it. Same source told me that it will take 4 plus years for the oils that are responsible for the allergic reaction to diminish to the point it can be worked.
>You should be able to get out there in the Winter with some loppers without too much risk, then get someone who is not allergic to cut it up for you after the vines have decay for some time.
As for cutting into lumber, you sawyer will probably take care of that. You obviously wouldn't want to put it on a horizontal mill with the curve up or down. THat would make the grain run-out up and down through the face.
Sawing with the curve flat to the bed, through and through, will allow the curve to the thickness of the plank, unless there is some spiraling grain, which is not unusual in edge or yard trees, in which case, you will be wasting your time on it.
Don't ask how I might know these things.
My suggestion, is to take your framing hammer out to it, Strike it across the grain at ~45� to knock some bark off. You can then see how the grain runs just under the bark. It is not unusual for cherry to start growing a block model figure on the inside of a crook, which can be kinda nice.
But if it has a lot of spiral grain due to lopsided canopy causing twisting action when the wind blows, the grain may resemble a bia-ply tire, which makes for some really twisted lumber that will be hard to use if you need strength, as in chair legs etc. where the grain follows the grown curve.
Stacking and stickering grown curved lumber is not pretty.
I have a really radical post oak that I am considering cutting down before long. It was laid over in an ice storm many years ago. It is about 20" DBH, then takes a giant N shape. I am thinking about chain-sawing a couple of slabs out of it maybe to use as bench seats.
>The ivy part is easy. Cut it now and soon the vines will be dead and when they dry out relatively harmless. I am exceptionally allergic to poison ivy but I find it benign after it has been cut and dried out.
Let me reemphasize the risks of cutting a leaning tree. While it might seem trivial, it's going to reliably fall the direction it is leaning, the risk is that it will fall at an unpredictable time due to the stress caused by its leaning. The result can be that the center of the tree will split out or the whole tree may split. the resulting pieces can travel in unexpected directions at a rate of speed that will exceed your reaction time. There are techniques for dealing with this situation that will be known to a timber cutter. Best to let the person doing the band sawing cut it, presuming he is experienced cutting timber.
>I'll get a rash if I touch poison ivy, but I've cut many hundreds of vines here at the farm, some upto 4" in diameter, and I've never had a problem. Some of the trees looked like poison ivy trees with long horizontal poison ivy branches extending up to the canopy!
I usually work when there are no leaves. If you cut in the winter you are naturally covered with more clothing which helps. If I do work without gloves or touch something, I simply wash up within 15 minutes or so.
I generally sever the vine near the ground and let it die and rot in the tree - if I get a log for my sawmill that is covered with vines, I'll wear gloves to pull it off and put the vines in the woods somewhere to rot. Be careful about burning poison ivy vines. I've heard stories of people who were so sensitive that the smoke would give them an allergic reaction. I'd hate to send a neighbor to the hospital.
I did accidentally find out something interesting about poison ivy vines - the irritant oils don't seem to be in the sap inside the vine. I was cutting a large vine with a bypass pruner one spring and somehow got a squirt of watery sap right in my eye. Yikes. I rinsed with water and expected a problem but it never came.
